Was it you? - Router Forums
post #1 of 7 (permalink) Old 06-07-2013, 11:55 PM Thread Starter
Honored Member
harrysin's Avatar
First Name: Harry
Default Was it you?
Would the member who sent me a message about the making of router skis please contact me again because the message ended up in my junk folder and was deleted.
Harry
harrysin is offline
post #2 of 7 (permalink) Old 06-08-2013, 07:23 PM
thbart's Avatar
First Name: Art
Harry,
It might have been me. I asked about useing SS 12mm threaded rod to make the skis. I ordered the rod and now that I have it, it seems to have a lot of flex. Will that mess up m skis? I couldn't find 12mm in the polished rod and 1/2 inch will not fit my Makita 2301 without drilling the base. Your guidance will be much appreciated.
Thank you,
Art
thbart is offline
post #3 of 7 (permalink) Old 06-09-2013, 02:53 AM Thread Starter
Honored Member
harrysin's Avatar
First Name: Harry
Originally Posted by thbart View Post
Harry,
Thank you,
Art
I'm sorry about the deletion of your first message, it was accidental. Many members have made ski rods using allthread, I really don't know with what success. Common sense says that it can't be as rigid as solid steel. Because I have a spare Makita base that suits the 3600BR, 3612 and 3612C, I went out to the shed and as these shots show, there is plenty of meat to allow the extra 0.7mm to be removed by drilling through with a 1/2" (12.7mm) twist drill. My 12mm rods are 27.5" long and have never shown any tendency to sag, bearing in mind that the ski assembly is operated by the end cheeks, NOT the router's handles. Don't hesitate to ask if you have further questions.
Harry
harrysin is offline
post #4 of 7 (permalink) Old 06-09-2013, 03:40 AM
carl.p's Avatar
Country: South Africa
First Name: carl
Default ski bars
Hi Harry what metal are you using for the ski bars is it just 1/2 inch bright steel or 316 stainless steel regards carl
Classical music is food for the mind and soul.
carl.p is offline
post #5 of 7 (permalink) Old 06-09-2013, 07:31 AM
thbart's Avatar
First Name: Art
Thank you for getting back to me. I guess I will give it a try with the all thread and see what happens. I can alway drill it and get some solid rods if the results aren't good. Thanks again.
thbart is offline
post #6 of 7 (permalink) Old 06-09-2013, 09:40 AM Thread Starter
Honored Member
harrysin's Avatar
First Name: Harry
Carl, I'm using bright mild steel which is so easy to turn down and thread. The 1/2" rod shown in the drilled out base is case hardened and polished mild steel, just an off-cut from my scrap metal stock.
Harry
harrysin is offline
post #7 of 7 (permalink) Old 06-12-2013, 11:13 AM
carl.p's Avatar
First Name: carl
thanks harry. regards carl
carl.p is offline
