Do I use guide bushings or ? - Router Forums
post #1 of 10 (permalink) Old 06-17-2013, 05:45 PM Thread Starter
First Name: Nick
Default Do I use guide bushings or ?
Ok I'm going to try to explain what I'm doing.
My stock is 2"x15" and down the middle will be an elongated "S". One side of the "S" will be white and the other will be black (not really, just painting a mental picture). Now I need the black side to be 1/4" below the white, and along the "S" will be a
1/4" cove.
Now my question is, should I use a guide bushing and templet, with a 1/4" core box bit and skis, or a bowl bit with a bearing and a templet with skis? And would I use the same bit to remove all of the remaining black side? I am willing to do it eather way I just don't know what is the best.
Nick
tcbnick is offline
post #2 of 10 (permalink) Old 06-17-2013, 06:40 PM
Hi Nick.
I have not seen a 1/4" bowl cutter, so I would go with the 1/4" core box bit.
Sydney, Australia
jw2170 is offline
post #3 of 10 (permalink) Old 06-17-2013, 07:40 PM
1 PC 1 4" SH 3 4" Dia Dish Bowl Tray Router Bit | eBay
post #4 of 10 (permalink) Old 06-18-2013, 05:45 AM
JOAT's Avatar
First Name: Theo
That sounds like one of those jobs you try with scrap first.
JOAT is offline
post #5 of 10 (permalink) Old 06-18-2013, 06:44 AM Thread Starter
First Name: Nick
I agree with using scrap first. But what method should be used, guide bushings or bearing bits?
Nick
tcbnick is offline
post #6 of 10 (permalink) Old 08-09-2013, 06:38 PM
jamminjack317's Avatar
First Name: Jack
I am still trying to get the mental picture out of my head!!
Never complain about getting old...
A lot of people are denied that privilege.
jamminjack317 is offline
post #7 of 10 (permalink) Old 08-09-2013, 06:47 PM
Honored Member
First Name: pat
Definitely bushings.
Quillman is offline
post #8 of 10 (permalink) Old 08-09-2013, 06:48 PM
MEBCWD's Avatar
Nick I think I'd go with a template and bowl cutter with bearing like the one in Bj's link. The bowl cutter will give you a flat bottom while cutting the cove you want on the BLACK side.
MEBCWD is offline
post #9 of 10 (permalink) Old 08-09-2013, 07:23 PM
Plus the bit can be used to make the template with just about any bowl or any candy dish..
post #10 of 10 (permalink) Old 08-10-2013, 06:06 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
Template and guide (bushing) without any doubt.
Harry
harrysin is offline
Oversized guide bushings and storage Mike Guide Bushings and Templates 7 09-04-2016 11:40 AM
Centering guide bushings...fail Bikeworks Guide Bushings and Templates 9 02-27-2013 07:17 PM
Metric bits and guide bushings Mike The Voting Booth 29 05-09-2012 09:08 AM
Base plates that recieve guide bushings TanOak Table-mounted Routing 10 10-15-2011 09:55 AM
Harbor Freight Guide Bushings Work Better. RJM60 Guide Bushings and Templates 0 08-02-2010 05:06 PM
