Template Guide for Makita Compact Router - Router Forums
post #1 of 12 (permalink) Old 09-07-2013, 10:38 AM Thread Starter
Default Template Guide for Makita Compact Router
Hello, I'd be happy if someone could help me out with this issue. I have a Makita Compact Router, RT0701C - 1-1/4 HP* Compact Router.
I have the plunge base for the unit and I don't know what exactly I need to put a template guide on the plunge base. I would like 1/2" guide and a 1/4" guide.
I have attached a couple of pictures of the plunger base. I would appreciate any help! Thank you.
Devon
Dyreson is offline
post #2 of 12 (permalink) Old 09-07-2013, 01:56 PM
Country: Brazil
First Name: Cláudio
In Brazil this model is RT0700C.
The Makita keeps the same diameter as the hole in the base.
This one should serve:
Makita 321492-3 Template Guide - Amazon.com
Router bushings
http://www.routerforums.com/introduc...-bushings.html
Botelho007 is offline
post #3 of 12 (permalink) Old 09-07-2013, 02:10 PM
Semipro's Avatar
First Name: John_*
Semipro is offline
post #4 of 12 (permalink) Old 04-05-2014, 07:00 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
All those guides appear to be for the full size routers like the 3600BR, 3612/C and RP2301FC and the adapter also for these models to take the two piece Brass guides, in which case they are far too big for the RTO-700C trim router.
Harry
harrysin is offline
post #5 of 12 (permalink) Old 04-05-2014, 09:20 AM
Country: Brazil
First Name: Cláudio
Default Makita 321492-3 Template Guide
Devon
Adapter manufactured for use in plunge base of the router RT0700.
Harrysin which adapter to use in dust collector RP2301FC?
I used an adaptation of the dust collector in RP2301FC.
post #6 of 12 (permalink) Old 04-05-2014, 10:37 PM
harrysin's Avatar
First Name: Harry
Claudio, I use the TRITON fitting as shown, it fits the dust chute of the Makita RP2301FC perfectly. I must confess That a lot of the time I remove the dust chute on critical jobs because it tends to obscure my view of the bit.
Harry
harrysin is offline
post #7 of 12 (permalink) Old 04-06-2014, 05:59 PM
Country: Brazil
First Name: Cláudio
Harry lacks the the dust chute of the Makita RP2301FC.
I got this:
Amazon.com: Makita 192035-6 Router Dust Nozzle (3606,3612,3621 Series): Home Improvement
I made an adjustment to use.
Follows the pictures.
Sorry failure in language.
post #8 of 12 (permalink) Old 04-07-2014, 07:33 AM
harrysin's Avatar
First Name: Harry
Now I can see why you made that excellent adapter Claudio, because your dust chute is for the earlier model 3612/C, this shot shows the correct dust chute for the RP2301FC
Harry
harrysin is offline
post #9 of 12 (permalink) Old 04-07-2014, 09:23 AM
Country: Brazil
First Name: Cláudio
Thank you Harry.
I will Search for where sells.
RP2301FC is already Musclechuck with type 9.
post #10 of 12 (permalink) Old 04-08-2014, 06:28 AM
harrysin's Avatar
First Name: Harry
I found it very hard to find information about the dust nozzle for the Makita RP2301FC, this item on Amazon claims it is for the RTO700CX3 but the illustration is IDENTICAL to the dust nozzle on my RP2301FC so I don't know if the description or the illustration is wrong!
Amazon.com: Makita 194733-8 Dust Extracting Nozzle with RT0700CX3 Plunge Base: Home Improvement
This link may be of interest, it lists the template guides which go up to 40mm with their part numbers. Bear in mind that these guides also fit the 3600BR and 3612/C routers.
http://www.makita.biz/product/catego...=1385823226566
Harry
harrysin is offline
Mixing Bosch 1617 Router fixed base with Craftsman professional router sf_basilix Starting Off 17 10-11-2012 05:20 PM
Thanks for a great forum tmutchf New Member Introductions 9 03-11-2010 04:43 AM
Harbor Freight 10 Piece Router Template Guide Set rstermer Guide Bushings and Templates 4 06-04-2008 05:56 PM
