osb vs particle board for templates? - Router Forums
post #1 of 26 (permalink) Old 12-06-2013, 03:20 PM Thread Starter
First Name: brandon
Default osb vs particle board for templates?
need some material for making guitar building templates and these are about all i can find at lowes. will either of these work?
7/16 x 4 x 8 OSB Sheathing $8.12
5/8 x 48 x 24 Premium Particleboard $7.68
The Outlaw is offline
post #2 of 26 (permalink) Old 12-06-2013, 03:23 PM Thread Starter
First Name: brandon
the only mdf i could find was a little thick and a little more than i wanted to spend
3/4 x 48 x 96 Premium MDF $34.12
the only hardboard i could find was a little thinner than i would like
DPI 3/16-in x 4-ft x 8-ft Brown/Unfinished Hardboard Wall Panel $13.48
post #3 of 26 (permalink) Old 12-06-2013, 03:27 PM
MDF would be a little better. It will sand to a smoother finish along the edges.The OSB might be hard to mark out because the surface is rough but I suppose either one of the two you mentioned would work if you can get the edges sanded smooth so that a bearing will follow them smoothly.
post #4 of 26 (permalink) Old 12-06-2013, 03:30 PM
The particle board isn't much cheaper at about $31 for 32 sq. ft.. You could go with 3/8 or 1/2 in most cases but that won't save you a lot.
post #5 of 26 (permalink) Old 12-06-2013, 03:32 PM Thread Starter
First Name: brandon
would the particle board be better/easier to use than the osb?
post #6 of 26 (permalink) Old 12-06-2013, 03:41 PM
GulfcoastGuy's Avatar
First Name: Patrick
Where are you?
GCG
___
"I was always afraid of dying. Always. It was my fear that made me learn everything I could about my airplane and my emergency equipment, and kept me flying respectful of my machine and always alert in the cockpit. " - Chuck Yeager
___
http://www.routerforums.com/table-mo...table-saw.html
GulfcoastGuy is offline
post #7 of 26 (permalink) Old 12-06-2013, 03:42 PM Thread Starter
First Name: brandon
Lock Haven PA
post #8 of 26 (permalink) Old 12-06-2013, 05:00 PM
JOAT's Avatar
First Name: Theo
I don't care for either. I use 1/2" plywood, two pieces glued together, giving me 1" thick templates - or masters as I call them. Gives a nice hefty bulk to hold on to.
JOAT is offline
post #9 of 26 (permalink) Old 12-06-2013, 08:38 PM
If you have to draw the patterns out and then cut and sand to the lines you will have trouble with the OSB's surface texture and color changes.
post #10 of 26 (permalink) Old 12-07-2013, 06:27 AM
For me, mdf is the way to go, smoother surface for the bearing to ride on equals a smoother cut with the bit, sometimes a little more money means a little less work in the end.
curly1 is offline
Routing rabbit in Melamine Particle Board JohnnyB60 General Routing 2 04-01-2012 11:38 AM
Free Particle Board 5x5 With Some Corner Damage Plywoodny The Bargain Bin 1 10-22-2009 05:27 AM
MDF & Particle Board senduran1982 New Member Introductions 2 08-05-2009 12:56 AM
