Purpose of different barrel length for guides?? - Router Forums
post #1 of 11 (permalink) Old 01-11-2014, 10:17 AM Thread Starter
First Name: Richard
Default Purpose of different barrel length for guides??
I'm new to this forum and have never used guides. Thanks to you I was able to purchase a Leigh template adapter for my Ryobi. I purchased a set of brass template guides from Harbor Freight. After trimming a few 1000's they are centered and fit the Leigh template.
My question: Is there any reason why the barrels protrude at different lengths? I understand the different diameters allow for larger bits, but if my pattern is only a 1/4 or 3/8" thick the larger length barrels are not useable. Do the longer barrels have a use?
bluewood is offline
post #2 of 11 (permalink) Old 01-11-2014, 10:58 AM
Honored Member
First Name: pat
They did.
They were a PC invention.
And the different barrel lengths accommodated their diverse fixturing.
Some of which still exists.
Quillman is offline
post #3 of 11 (permalink) Old 01-11-2014, 12:06 PM
Richard, this is why I recommend the set from Woodcraft where all the guides are the right length for use with 1/4" templates.
post #4 of 11 (permalink) Old 01-11-2014, 12:21 PM
First Name: Phillip
How do I fix these into, say, the base of my plunge router? Bosch 1617.
To change the world, change your mind.
phillipdanbury is offline
post #5 of 11 (permalink) Old 01-11-2014, 01:17 PM Thread Starter
First Name: Richard
Thanks, I will trim these down to 1/4".
bluewood is offline
post #6 of 11 (permalink) Old 01-11-2014, 04:13 PM
Honored Member
First Name: pat
"How do I fix these into, say, the base of my plunge 1617 etc.........."
With one of these, for example.
Quillman is offline
post #7 of 11 (permalink) Old 01-11-2014, 07:11 PM
Richard, you will want them a small amount under 1/4" so they have clearance, about .230".
Phillip, There are several solutions and Pat's high precision base is one of them. I use the Bosch parts which work with their dust collection adapters. You will find a list of all the 1617 accessories in a sticky thread at the top of our general routing section.
post #8 of 11 (permalink) Old 01-12-2014, 01:44 PM
tvman44's Avatar
First Name: Bob
Mike, what is the title of that sticky. I cannot find it. I know the problem is me but would like to read that thread.
TIA, Bob
Papa Bob
Using a couple of old Craftsman routers & a Bosch 1617EVSPK & a Dewalt DWP611PK Routers in SW Louisiana.
tvman44 is offline
post #9 of 11 (permalink) Old 01-12-2014, 03:26 PM
MT Stringer's Avatar
The template set Mike referred to is on Sale at Woodcraft through Jan 24th.
MT Stringer is offline
post #10 of 11 (permalink) Old 01-12-2014, 06:10 PM
http://www.routerforums.com/general-...tml#post282880
Shank Length vs. Cutting Length (or carbide height) in Straight Bits xzJoel Router Bits - Types and Usage 4 05-12-2012 11:11 PM
Length of Ski Rods Marco Jigs and Fixtures 9 03-17-2011 07:43 AM
New router and which starter router bits for my useage? Skyglider Router Bits - Types and Usage 11 12-08-2010 10:42 PM
Guide bushing length crquack Guide Bushings and Templates 17 01-27-2010 07:06 AM
5mm barrel hinges awoodnut General Routing 8 11-17-2009 06:28 PM
