longer router bits for loose-tenon mortise cuts with guide bushings? - Router Forums
post #1 of 12 (permalink) Old 03-15-2014, 04:17 PM Thread Starter
First Name: dusty
Default longer router bits for loose-tenon mortise cuts with guide bushings?
I just got a little Dewalt DWP611 router with plunge base which takes guide bushings.
I want to cut mortises for loose tenons. Is there such a thing as an extra-long router bit for this purpose? When the router is fully inserted into the base and can go no further, only 1/2" of cutting edge protrudes beyond the guide bushing.
mrblint is offline
post #2 of 12 (permalink) Old 03-15-2014, 05:39 PM
Honored Member
First Name: pat
There are plenty but not for your 1/4" collet (for safe use).
You need a bigger router for blind deep cuts like mortices.
Quillman is offline
post #3 of 12 (permalink) Old 03-16-2014, 08:10 AM Thread Starter
First Name: dusty
Couldn't the mortise cut be made reasonably safe if the plunge-router's step-turret is used to make the cuts in three or four shallow passes?
mrblint is offline
post #4 of 12 (permalink) Old 03-16-2014, 09:00 AM
Shortslvs's Avatar
First Name: Fred
I think it is one of those "can I do it" vs "should I do it" things.
If you plan to do this very often you really should move up to half inch and the largest diameter you can use. Then apply the same practice you suggest for the 1/4 bit.
Eventually a bit will break, so approach every operation like this is the time it is going to happen and try real hard to not do anything that will make it more likely to happen.
I appreciate you posting this question. I've been sitting here thinking about "best practices" in my daily shop operation. One of my kids works for me now and I think it might be time to have another "right tool right job" talk coupled with "complacency kills". I feel sorry for my kids sometimes, but not so sorry that I won't preach another sermon about the dangers of fast spinning whirly steel and carbon things. I should probably do a quick powerpoint with some severed digits pics to drive some points home. Hahaha
Sorry everyone
Shortslvs is offline
post #5 of 12 (permalink) Old 03-16-2014, 10:23 AM
ghsu2ia3 | eBay
1 PC 1 4" SH 2" Blade Extra Long Straight Router Bit | eBay
post #6 of 12 (permalink) Old 03-16-2014, 11:17 AM
Honored Member
harrysin's Avatar
First Name: Harry
You haven't said what the shank and blade lengths are Dusty. As for template guides, sure they can be used, but in conjunction with TEMPLATES. Perhaps this simple jig that I made would suit your purpose.
Harry
harrysin is online now
post #7 of 12 (permalink) Old 03-16-2014, 11:41 AM
Country: Brazil
First Name: Cludio
A few more ideas.
Сверлока - YouTube
Router bits with shank 1/2" for best mortise.
Work done more safely.
Botelho007 is offline
post #8 of 12 (permalink) Old 03-16-2014, 06:57 PM
Question
Try putting the cutter only 1" into the collet to see if you get any more length.
"fully inserted into the base"...does not tell me how far into the collet you are going?
What is the length of the cutter blades?
Sydney, Australia
jw2170 is offline
post #9 of 12 (permalink) Old 03-16-2014, 08:57 PM
Selwyn Senior's Avatar
First Name: Peter
Default Router Bit Selection
Dusty,
When mounting a bit in the collet you should insert it all the way and then pull it back a little. The reason for having a small portion of the shank exposed deals with transfer of heat when the bit is under load. Pulling it out further to gain a little cutting depth may be a trade off for safety and/or snapping a bit that isn't properly supported.
I have also switched to 1/2" shafts from 1/4" which gains strength among other benefits.
Is there a bit more suited to the job. For example you might want to research an upsprial bit as it clears the waste out of the channel as it cuts?
Could you use a drill (press) to clear out most of the mortise and then a router bit to clean the edges?
Just a couple of thoughts.
Selwyn Senior is offline
post #10 of 12 (permalink) Old 03-17-2014, 08:14 AM
Honored Member
harrysin's Avatar
First Name: Harry
Every collet that I have tested measures 1" (25mm), therefore as stated in the summary of my recent thread on bit insertion, there is nothing to be gained by inserting the bit any further than 1".
Harry
New Router my way reible General Routing 21 12-08-2018 12:06 PM
Getting Started With A Woodworking Router. learnexperience Table-mounted Routing 9 10-22-2014 07:43 PM
Mortise & Tenon Jig for the Plunge Router bobj3 Jigs and Fixtures 45 03-24-2013 10:58 AM
Guide bushings for Craftsman 17517 plunge router? badmajon Guide Bushings and Templates 6 05-20-2010 11:19 AM
Mortise & Tenon System Router questions kenadian Table-mounted Routing 2 11-17-2005 04:22 PM
