Guide bushing for Brusso templates - Router Forums
post #1 of 12 (permalink) Old 05-08-2014, 09:23 PM Thread Starter
First Name: Bob
Default Guide bushing for Brusso templates
I am considering using Brusso hinges on a few projects and have some questions regarding the use of their installation templates.
I believe that their templates are made of 1/8" brass.
The instructions contain the following:
shorten the bushing to protrude from the bottom of the router base by slightly less than 1/8"
Since none of my bushings are that short,
should I buy a new bushing and modify it as per the instructions or
could I just make a spacer (of maybe MDF and the size of the router base) to go over the standard bushing and of a thickness to achieve the same result.
Thanks in advance
HawaiiBob is offline
post #2 of 12 (permalink) Old 05-08-2014, 10:45 PM
That should work, Bob.
You are effectively dropping the guide bushing deeper into the base plate.
Sydney, Australia
jw2170 is offline
post #3 of 12 (permalink) Old 05-09-2014, 03:18 AM Thread Starter
First Name: Bob
Thanks James
I did not think it would be an issue and being a tight-arse, the spacer is the cheaper way out.
post #4 of 12 (permalink) Old 05-09-2014, 09:02 AM
Honored Member
First Name: pat
"I just make a spacer (of maybe MDF and the size of the router base) to go over the standard bushing and of a thickness to achieve the same result."
I don't think so unless the first ring is = 1/8 or less.
Would definitely get a new ring and grind it down to their specks.
Quillman is offline
post #5 of 12 (permalink) Old 05-09-2014, 06:46 PM
Hi Pat,
I am familiar with your method, and in fact recommended that method in a recent post.
However, I am not sure why the OP's solution would only work if "the first ring is = 1/8 or less"?
Sydney, Australia
jw2170 is offline
post #6 of 12 (permalink) Old 05-09-2014, 07:49 PM
Honored Member
First Name: pat
Longer extension, probably longer than the templet is thick?
In that event, it won't work; it will hit the work.
Quillman is offline
post #7 of 12 (permalink) Old 05-10-2014, 06:18 PM
Thanks Pat. I re-read the OP and the penny dropped....
If the template is only 1/8", a very short guide bushing will be required...
Sydney, Australia
jw2170 is offline
post #8 of 12 (permalink) Old 05-11-2014, 12:33 AM Thread Starter
First Name: Bob
So why would a spacer the size of the router base and thick enough to only allow the guide bushing to protrude through it less than the thickness of the template NOT work?
post #9 of 12 (permalink) Old 05-11-2014, 09:17 AM
Honored Member
First Name: pat
Most (PC/DW) collars are flanged and sit in the couterbore on the work side of the subbase, example..
As such, a spacer, as you suggest does nothing.
Quillman is offline
post #10 of 12 (permalink) Old 05-11-2014, 10:45 AM Thread Starter
First Name: Bob
Pat, If the 'spacer' is between the router base and the work, and only allowing the guide bushing to protrude the required amount, please explain how that would not work.
Guide bushing identification Mike Guide Bushings and Templates 42 09-22-2013 08:25 PM
Guide bushing fabrication johnpaulh Guide Bushings and Templates 10 01-30-2012 06:32 AM
Guide bushing length crquack Guide Bushings and Templates 17 01-27-2010 06:06 AM
Router template inlay V Garry General Routing 7 12-27-2008 06:49 PM
