Butterfly Template - Router Forums
post #1 of 4 (permalink) Old 05-21-2014, 07:06 PM Thread Starter
lenh's Avatar
First Name: Len
Default Butterfly Template
Not sure how to exactly explain this so I have included a picture. I have created the male portion of an inlay - a butterfly. I need to now create the template for the female to exactly the match the male. I've done many square, round, oval, etc. templates but this is a bit different. How do I do it? Somehow I need to draw a larger image that includes the offset then cut out the outer perimeter the use a guide bushing with a collar to make the inlay. Possibly need to just skim the outer circumference of the male portion. The male part has been scroll sawn and glued together using several different colors and species of wood (1/8")
lenh is offline
post #2 of 4 (permalink) Old 05-27-2014, 10:10 PM
Smile
Hi Len, I did not answer before as I though that some one could come along and answer your question in a easier manner.
On an episode of The Router Workshop, Bob showed how to do that using an inlay set.
Do you have one?
MLCS router inlay set
I will see if I can find the episode and try and explain the process.
Sydney, Australia
jw2170 is offline
post #3 of 4 (permalink) Old 06-02-2014, 08:47 AM Thread Starter
lenh's Avatar
First Name: Len
Do you have one?
James, thanks so much. I am still wrestling with the project I'm making. I have both the 1/8" and 1/4 inlay sets. Looking forward to viewing the episode. Thanks again!
Len
lenh is offline
post #4 of 4 (permalink) Old 12-07-2014, 11:20 PM
TarterWoodworking's Avatar
First Name: Larry
Len, Hope Im not to late to help, but Im new to this forum.
I work for TarterWoodworking.com and we design easy to use templates to make these type of inlays simple. We use multiple layer inlay template designs... I think you will really like what you find to make this project and future ones a lot easier.
Heres a sample...
TarterWoodworking is offline
Porter Cable 55160 Omnijig Review Echonav Tool Reviews 19 06-21-2015 03:59 AM
Using a portion of a template to make a project kp91 Guide Bushings and Templates 2 06-08-2012 03:45 PM
REAL butterfly inlay template? Rogue Teardrops General Routing 2 09-01-2011 05:11 PM
How to make a template accurate? Steve Blackdog Guide Bushings and Templates 4 01-02-2011 04:44 PM
Template Routing FlyFAmerica Portable Routing 11 12-21-2008 01:36 PM
