Part six in my series Routing for beginners - Router Forums
post #1 of 6 (permalink) Old 06-09-2014, 08:56 AM Thread Starter
RouterForums.com User
harrysin's Avatar
First Name: Harry
Default Part six in my series Routing for beginners
This tutorial in pdf format shows the design and routing of an octagonal Art Deco style clock. Each step has been photographed and explanatory text added. As always, never be shy to ask questions on any aspect that you don't understand.
Harry
harrysin is offline
post #2 of 6 (permalink) Old 06-09-2014, 06:15 PM
old55's Avatar
First Name: Ross
Thanks Harry.
Ross,
old55 is offline
post #3 of 6 (permalink) Old 06-09-2014, 07:40 PM
RainMan 2.0's Avatar
That's impressive Harry . I would have never understood how it was done had I not seen this
Harry with the router base guides you must have been very careful not to let the guide come off the template at all I suspect. Seems like it would be a little precarious to me . I'm sure impressed with the outcome though
RainMan 2.0 is offline
post #4 of 6 (permalink) Old 06-09-2014, 09:06 PM Thread Starter
harrysin's Avatar
First Name: Harry
You're correct Rick, it's most important that the bench height is ideal and the jig holder close enough to enable the operator to maintain router pressure against the edge of the template, also it's important that only shallow cuts of about 3mm are taken so that the grain doesn't attempt to control the direction of the bit. I purposely did not go into the fine detail as I have in parts 1-5 in the series "routing for beginners" because by the time the "beginner" has reached this part six, he/she will have acquired sufficient knowledge to fill in the gaps.
Harry
harrysin is offline
post #5 of 6 (permalink) Old 06-10-2014, 06:15 AM
Talking
Excellent tutorial and result Harry.
Can I take credit for being the inspiration for this>>>>>>..
I can see I am going to have to get out in the "shed"....
Sydney, Australia
jw2170 is offline
post #6 of 6 (permalink) Old 06-10-2014, 08:57 AM Thread Starter
harrysin's Avatar
First Name: Harry
You certainly can take full credit for the inspiration James. When you made your octagonal bowl I decided to make one, the difference to be that it would be fully routed, then I had second thoughts and made the clock. I will however rout a bowl using the same octagonal template plus a second one for the inside as my next project.
Harry
harrysin is offline
powrkraft radial arm saw routing iowaboy General Routing 16 11-01-2019 09:41 AM
old person new to routing in wood sailer670 New Member Introductions 12 12-13-2014 07:31 PM
A routing tutorial for beginners Part Four harrysin Guide Bushings and Templates 23 04-21-2013 09:31 AM
Craftsman Jointer Part Repcobpg Tools and Woodworking 21 10-01-2012 05:58 AM
Part one of a two part thread harrysin Woodturning and Lathes 15 10-07-2008 10:50 PM
