Bosch router table - need guide bushings - Router Forums
post #1 of 12 (permalink) Old 06-19-2014, 08:27 PM Thread Starter
First Name: WM
Default Bosch router table - need guide bushings
I have a RA1171 Bosch Router table with a Bosch 1617EV Router.
I would like to be able to use guide bushings on the table but am having difficulty finding guide bushings that will fit any of the inserts.
Has anyone come across a solution for this??
becikeja is offline
post #2 of 12 (permalink) Old 06-19-2014, 08:48 PM
RainMan 2.0's Avatar
I don't know if this helps , but here's a link to a sticky thread where Mikes showing a bunch of bushings for what I think is your router . Just go down the page
http://www.routerforums.com/general-...1617evstb.html
Update : Sorry WM , I may have misunderstood your question
RainMan 2.0 is online now
post #3 of 12 (permalink) Old 06-20-2014, 12:51 AM
Welcome to the forum, WM.
Usually, the smallest insert ring will take the PC style guide bushing.
Did you table come with the 3 insert rings?
Sydney, Australia
jw2170 is offline
post #4 of 12 (permalink) Old 06-20-2014, 12:55 AM
Semipro's Avatar
First Name: John_*
WM, glad to see you join our community
Thank You John
Semipro is offline
post #5 of 12 (permalink) Old 06-20-2014, 10:52 PM Thread Starter
First Name: WM
The table did come with 3 inserts, but the PC bushing I have does not fit any of them. I have always thought of Bosch as a good mid range power tool company, so I find it odd they don't have bushings for their router table.
I'm sure there is a simple solution, I just need to find it. Appreciate the comments.
Thanks for the welcome to the forum.
becikeja is offline
post #6 of 12 (permalink) Old 06-21-2014, 02:01 AM
What are the 3 hole sizes for your insert rings?
Does the smallest have a lip on the inside?
Sydney, Australia
jw2170 is offline
post #7 of 12 (permalink) Old 06-21-2014, 08:01 AM
BrianS's Avatar
First Name: Brian
Hi WM, welcome to our little corner of the 'net.
Not sure if this is what you are looking for or not, but this will allow you to use the PC style of bushing with your Bosch router.
Bosch threaded template adapter
Brian
(Origin uncertain)
BrianS is offline
post #8 of 12 (permalink) Old 06-21-2014, 04:04 PM
First Name: Barry
WM. If I understand you correctly, you're trying to fit an adapter into the red plastic rings that fit into the mounting plate in the table. I don't believe the adapters will fit into them. The adapter is made to fit into the base plate of the router itself. If I misunderstand your question you can disregard my answer.
Barry747 is offline
post #9 of 12 (permalink) Old 06-21-2014, 05:52 PM
paduke's Avatar
I own a RA1187 It comes with three inserts none of which will accept a PC bushing. I checked boschtools.com and cant find insert plates listed under accessories.I have always used another table when using pc bushing and never noticed till this post and I went and checked
paduke is offline
post #10 of 12 (permalink) Old 06-21-2014, 07:23 PM Thread Starter
First Name: WM
I have seen the adapter that goes on the router. More interested in a bushing I can connect in the table inserts. Thanks for all the comments
becikeja is offline
Mixing Bosch 1617 Router fixed base with Craftsman professional router sf_basilix Starting Off 17 10-11-2012 05:20 PM
Use of Guide Bushings on the Router Table Mike Wingate Guide Bushings and Templates 23 12-28-2009 07:20 PM
Will Bosch RA1171 table handle 3 1/2 HP router? LBrandt Table-mounted Routing 3 03-25-2007 10:05 PM
