Brass guide bushings , how tight should the back ring be ? - Router Forums
post #1 of 13 (permalink) Old 06-29-2014, 08:41 AM Thread Starter
RainMan 2.0's Avatar
Default Brass guide bushings , how tight should the back ring be ?
Guys I was trying to make a template yesterday and I have an adaptor for my Festool router so now I can use those brass guide bushings , but I only tightened that brass ring that threads from in behind as tight as I could get it with my fingers and it backed off during use .
That brass ring does have a knurled perimeter so it lead me to believe it was supposed to be hand tightened . But I got out my channel locks and gave it an extra bit of a turn so it didn't happen a second time .
I was quite careful as I believe it would take next to nothing to elongate the ring under pressure with channel locks
RainMan 2.0 is offline
post #2 of 13 (permalink) Old 06-29-2014, 08:49 AM
Andy Bardowell's Avatar
First Name: Andy
Strange I've only ever had to hand tighten but it depends on how much room you have to get your hand in there and of course how much strength you have in your hands. A senior for example may have more difficulty but if you proceed with small turns as you said you should be ok 1/8ths perhaps.
Andy
Andy Bardowell is offline
post #3 of 13 (permalink) Old 06-29-2014, 09:31 AM
Honored Member
First Name: pat
Hard to measure, probably 3-5 inch-pounds.
But before routing test it against a high friction edge.
Back and forth; it must not loosen. You're wise to be concerned.
Lose a ring under power and there will be adversity.
Quillman is offline
post #4 of 13 (permalink) Old 06-29-2014, 10:09 AM
tvman44's Avatar
First Name: Bob
I put finger tight, but I have strong hands & fingers.
Papa Bob
Using a couple of old Craftsman routers & a Bosch 1617EVSPK & a Dewalt DWP611PK Routers in SW Louisiana.
tvman44 is offline
post #5 of 13 (permalink) Old 06-29-2014, 10:20 AM Thread Starter
I'm a wuss ,explains everything lol
post #6 of 13 (permalink) Old 06-29-2014, 10:22 AM Thread Starter
Andy that's pretty much what I did . Just gave it that extra little turn as I suspected it was only supposed to be hand tight
post #7 of 13 (permalink) Old 06-29-2014, 01:46 PM
Semipro's Avatar
First Name: John_*
Have you ever had your template guide bushing vibrate loose while in the middle of a cut? With this new spring washer you won't have to worry about loosening bushings ever again. The 1- 3/16" O.D spring washer provides the perfect amount of resistance against the locking nut to keep your template guide bushing firmly locked in place.
Peachtree sells them
Semipro is offline
post #8 of 13 (permalink) Old 06-29-2014, 03:26 PM Thread Starter
Thanks John I'll look into that .
It's funny as even though I gave the collar a small extra twist I managed to break it loose with my hands
post #9 of 13 (permalink) Old 06-29-2014, 05:28 PM
As a 'senior', I admit I only ever hand tighten my brass rings.
The only time I have had one come loose was when I plunged the collet too far and it unwound the bushing.
Sydney, Australia
jw2170 is offline
post #10 of 13 (permalink) Old 06-29-2014, 06:06 PM
Also thought that feed direction may affect the locking.
Feed the correct way and the bushing is tightened, feed the wrong way and the bushing may come loose....
Sydney, Australia
jw2170 is offline
Metric guide bushings for Dewalt 625E & Elu OF97E vjeko Guide Bushings and Templates 13 11-24-2013 01:15 PM
Centering guide bushings...fail Bikeworks Guide Bushings and Templates 9 02-27-2013 07:17 PM
Guide bushings Tazkb Guide Bushings and Templates 3 11-22-2011 10:31 AM
Base plates that recieve guide bushings TanOak Table-mounted Routing 10 10-15-2011 09:55 AM
