A visual of how my template was made - Router Forums
post #1 of 5 (permalink) Old 07-18-2014, 10:04 PM Thread Starter
RainMan 2.0's Avatar
Default A visual of how my template was made
Guys for the longest time I just could not visualize why I couldn't use the same guide and bit for a template .I'm sure this has been discussed but today I used photoshop to help me see why things don't add up . I hate talking lol but I had to say what was going on during the video
ScreenCapture 7 18 2014 6 27 01 PM - YouTube
Ok ,I never insulate
RainMan 2.0 is offline
post #2 of 5 (permalink) Old 07-19-2014, 12:16 AM
nicely done..
post #3 of 5 (permalink) Old 07-19-2014, 07:03 AM
dutchman 46's Avatar
First Name: Howard
Good Morning Rainman! You have the correct idea! Depending on how thick Your table is,Your first cut would be with the hole with the large collar. This would cut through the table with succeesive cuts. Then with the small collar, using the same bit, to dut the ledge for the plate to rest on. Consider using a glue gun to but some bracing across the cut-out to hold the scrap in plsce. This gives You a bace to rest the collar on the waste side. I think I have it correct. I can not go to My bacement to check My theroy out , but this should work! Have a Great day!
John 3:16
dutchman 46 is offline
post #4 of 5 (permalink) Old 07-19-2014, 07:45 AM
paduke's Avatar
Developing 3-d rotary cutting logic is hard!!!!!!!!!!!! It has been the key for my successfully transitioning from commercial construction skill set into shop work skill set. Your visual is a great demo of the math formula I can never remember good post on a topic
paduke is offline
post #5 of 5 (permalink) Old 07-19-2014, 01:05 PM
Semipro's Avatar
First Name: John_*
I am impressed Rick, nice presentation
Semipro is offline
Having a Template made Marco Guide Bushings and Templates 8 02-07-2013 04:27 PM
Template guides question needlerockrick New Member Introductions 4 01-29-2010 09:23 AM
Routing with Template Tom template tom Guide Bushings and Templates 82 04-14-2009 02:25 AM
Router template inlay V Garry General Routing 7 12-27-2008 06:49 PM
