Multi-sized Hole template - Router Forums
post #1 of 4 (permalink) Old 07-28-2014, 04:40 PM Thread Starter
Country: Spain
First Name: Ray
Default Multi-sized Hole template
My jig/template for cutting out smaller holes of almost any size is made by cutting a hole of each diameter with a set of holesaws and then using bushes of 10,14 or 20mm dia with (usually) either a 6,7,8 or 9mm straight cutter. this provides for any size hole from about 60mm down to about 6mm.
I find it best to mark out the vertical and horizontal centre lines for each circle with a marking knife so as to aid in positioning the template. Hardboard will do, varnish it if you want!
Photo of template below.
RayArdia is offline
post #2 of 4 (permalink) Old 07-28-2014, 04:58 PM
Semipro's Avatar
First Name: John_*
Good idea Ray,it would take a little time to product the template but save lot later.
Semipro is online now
post #3 of 4 (permalink) Old 07-29-2014, 03:13 PM Thread Starter
Country: Spain
First Name: Ray
Thanks for your comment Semipro. This template took about a quarter of an hour, not counting the varnishing, which really is not necessary anyway.
I don-t think that-s too long, and it is quite handy!
RayArdia is offline
post #4 of 4 (permalink) Old 07-29-2014, 07:07 PM
RainMan 2.0's Avatar
Ok now I get it. I wasn't understanding the concept till I re read that guide bushings are being used .
Do you secure the template with screws most of the time or is it big enough to give you room to clamp?
Ok ,I never insulate
RainMan 2.0 is online now
Bosch 1617 screw hole template bigroccrek Table-mounted Routing 6 09-04-2016 12:30 PM
Porter Cable 55160 Omnijig Review Echonav Tool Reviews 19 06-21-2015 03:59 AM
RA1165 screw hole template mickelsen Table-mounted Routing 7 08-10-2012 07:55 PM
Beginner Question: Should/Could I use a template to cut a hole like this? dbishopbliss Guide Bushings and Templates 9 08-10-2012 03:16 PM
Adjustable Shelf Hole Template SkyKing Portable Routing 13 03-30-2006 01:48 PM
