Using PC bushings w Bosch 1617 - Router Forums
post #1 of 9 (permalink) Old 09-08-2014, 12:21 AM Thread Starter
First Name: tom
Default Using PC bushings w Bosch 1617
This summer I bought 2 adapters from Bosch to allow me to use my existing PC bushing set which I bought 30 years ago and never opened the box. Would I have been smarter to use Bosch bushing set.
floridagramps is offline
post #2 of 9 (permalink) Old 09-08-2014, 01:11 AM
yes...
centering them and keeping them centered may become an issue...
Stick486 is offline
post #3 of 9 (permalink) Old 09-08-2014, 08:05 AM
tvman44's Avatar
First Name: Bob
I have no problems with mine.
Papa Bob
Using a couple of old Craftsman routers & a Bosch 1617EVSPK & a Dewalt DWP611PK Routers in SW Louisiana.
tvman44 is offline
post #4 of 9 (permalink) Old 09-08-2014, 09:15 AM
Honored Member
First Name: pat
Seems PC/DW collars, in spite of their shortcomings, are the defacto industry standard. Since you have them, try them, might be the answer and the cheapest way.
Quillman is offline
post #5 of 9 (permalink) Old 09-08-2014, 11:39 AM
Forum Moderator
MT Stringer's Avatar
I am using Harbor Freight knockoffs of the Porter Cable style bushings with my Bosch. The first adapter screws to the housing. The second adapter snaps into place and is held there by the first one.
The bushings are then inserted and locked down with the tightening ring. I haven't noticed any play in the setup.
MT Stringer is offline
post #6 of 9 (permalink) Old 09-08-2014, 01:08 PM
oldwoodenshoe's Avatar
First Name: Glenn
I have both the Bosch PC bushing adaptor and the Bosch bushings for my Bosch router. Both work well.
oldwoodenshoe is offline
post #7 of 9 (permalink) Old 09-08-2014, 01:27 PM
MikeMa's Avatar
I have this on one of my plunge bases for my 1617 router. Works great, and stays centered.
Buy Router Base Plate with Centering Pin at Woodcraft.com
-Mike
Visit my woodworking blog: http://madermadeit.com/
MikeMa is offline
post #8 of 9 (permalink) Old 09-08-2014, 04:47 PM
Country: Brazil
First Name: Cláudio
Default Rockler One Plate
I have used this board I bought at Rockler, with PC type bushings and is perfect.
Did not find this board again at Rockler.
Botelho007 is offline
post #9 of 9 (permalink) Old 09-16-2014, 07:43 AM
First Name: Brad
Originally Posted by Quillman View Post
Seems PC/DW collars, in spite of their shortcomings, are the defacto industry standard........................................
Yep. Even my router uses them.
Just remember what my father always said, " Half the people in this world are below average!", and everything in life will make a hellova lot more sense.
timbertailor is offline
table/adjustment questions for Bosch 1617 and MR 23 enthusiasts achoox4 Table-mounted Routing 5 06-20-2014 03:38 PM
Mixing Bosch 1617 Router fixed base with Craftsman professional router sf_basilix Starting Off 17 10-11-2012 05:20 PM
Bosch 1617 Router JRay44 Table-mounted Routing 3 08-29-2012 10:22 PM
Guide bushing set for Bosch 1617 sofasurfer General Routing 8 02-05-2010 12:34 PM
matching Bosch router to PD guide bushings. drtimdc Guide Bushings and Templates 5 01-03-2010 06:18 AM
