how to make a bowtie inlay - Router Forums
post #1 of 7 (permalink) Old 10-01-2014, 03:34 AM Thread Starter
First Name: tom
Default how to make a bowtie inlay
I have a bow tie template, bosch 1617 plunge base router w adapters for PC bushings and a set of PC bushings. I have light and dark colored wood 1/4 inch thick
How do I route a recess in light colord wood
How do I route an inlay using dark colored wood
Once I master these simple mechanics, I'd like to try various inlays in gift projects.
All suggestions much appreciated
floridagramps is offline
post #2 of 7 (permalink) Old 10-01-2014, 07:00 AM
First Name: Dick
Hi Tom. This video will give you the exact information you need.
Router Bit of the Month -- Solid Brass Inlay Kit - YouTube
Dick
Where there's a Willis there's a way!
Willway is offline
post #3 of 7 (permalink) Old 10-01-2014, 07:40 AM
Country: South Africa
First Name: Denis
You don't have to buy an inlay kit. The trick is to find a combination of bit diameter and two bushes that satisfy the following relationship: outside diameter of larger bush minus outside diameter of smaller bush equals twice the bit diameter. The formula is simple: finding the right combination of bit and bushes is sometimes a problem.
A combination that works is:
Bit diameter: 5mm
OD of smaller bush: 10mm
OD of larger bush: 20mm
It works because (20 –10) = 2 x 5. An Imperial combinations that work are:
Bit diameter: 1/8”
OD of smaller bush: 1/2”
OD of larger bush: 3/4” and
The Imperial size bushes mentioned above are available for Bosch routers. Part numbers are RA1109 and RA1115. You might consider the Bosch guide bush kit RA1125 which contains seven bushes including the above two sizes plus a Porter Cable adapter. If you have already bought the kit featured in the video you will need a PC adapter. This is available individually as RA1100.
Denis Lock ("Routing with Denis")
denis.lock is offline
post #4 of 7 (permalink) Old 10-01-2014, 07:47 AM
First Name: del
what this u-tube and you will have a good idea how to do that, i have that same kit, [url=http://www.youtube.com/watch?v=HER0GeyG5cU]Router Bit of the Month -- Solid Brass Inlay Kit - YouTube[/url
you can also make any kind on inlay you want just draw it out and cut it out, follow the u-tube video for this
del schisler
port st. lucie, florida
del schisler is offline
post #5 of 7 (permalink) Old 10-01-2014, 12:03 PM
Country: Brazil
First Name: Cláudio
Default Router Inlay Practice - The Diamond
It is not the butterfly, but shows how to do.
https://www.youtube.com/watch?v=9-7HLAVD7b0
Botelho007 is offline
post #6 of 7 (permalink) Old 10-02-2014, 10:00 PM
First Name: Allen
Denis Thanks for the info on how to select bit and bushing sizes. Very helpful.
firstmuller is offline
post #7 of 7 (permalink) Old 10-02-2014, 10:29 PM
Great advice, there, Dennis.
Very simple when you explain it like that...
Sydney, Australia
jw2170 is offline
Mini Fence by Krymi Corp CharleyL Tools and Woodworking 37 07-23-2018 07:58 PM
Make a compass (Aluminium) robolop Show N' Tell 5 02-05-2014 06:53 PM
Lets make a Jewlery Case neville9999 General Routing 1 11-21-2013 08:06 PM
How to Make a Box learnexperience Tools and Woodworking 0 08-04-2011 11:30 AM
How to make a template accurate? Steve Blackdog Guide Bushings and Templates 4 01-02-2011 04:44 PM
