template help please - Router Forums
post #1 of 10 (permalink) Old 10-24-2014, 12:47 AM Thread Starter
First Name: Larry
Default template help please
i am attempting to pattern cut various shapes, which isnt an issue....yet. My problem is making the same cut about a half inch away to form a platter or tray, they say to cut the interior use a compass and trace the half inch and bandsaw it out....im not that steady or patient...how can i make a template to zip around the outside and get the same half inch all the way around?
Larry DK is offline
post #2 of 10 (permalink) Old 10-24-2014, 07:00 AM
Default try something like this
I believe these are referred to as scribing wheels. I have seen cheaper ones, but I can't find them right know. You could also go to a craft store and purchase various small wooden wheels for toys. Then drill the axle hole to fit your pencil.
I can't post links
Go to Am*zon, search for Perfect Butt Profile Scriber.
olliecooper is offline
post #3 of 10 (permalink) Old 10-24-2014, 07:44 AM
Cordyline's Avatar
First Name: Cordy
Thanks for tip olliecooper; I found lots of further info on youtube
Cordyline is offline
post #4 of 10 (permalink) Old 10-24-2014, 11:21 PM
JOAT's Avatar
First Name: Theo
Didn't understand what you wanted to do at first. I'd just drill a hole for the pencil in a piece of wood, then cut a point, sanding it down to be precise. Then just use that to get the half inch, or whatever size. Or use a compass.
JOAT is online now
post #5 of 10 (permalink) Old 10-29-2014, 10:30 PM
Larry, you do not say if the 'shapes' are regular or irregular...
If they are regular shapes such as bowls, dishes or small trays, look for some of the 'beginners' series by Harrysin.
Harry uses a "plug" with a guide bushing to cut the outer walls.
Sydney, Australia
jw2170 is offline
post #6 of 10 (permalink) Old 12-08-2014, 02:06 PM
TarterWoodworking's Avatar
First Name: Larry
how about using a hole saw and simply sanding the cutout piece till its smooth and use it like olliecooper said.
TarterWoodworking is offline
post #7 of 10 (permalink) Old 12-15-2014, 10:20 AM
Larry, I've made multiple routed bowls over the past couple of years and you will either need to bandsaw or scrollsaw the bowl out or, make your own template 1/2 in larger than the original template. My scrollsaw will give a much smoother cut than my bandsaw if the bowl depth is less than 2 inches. I need to add I have never made a template for this purpose.
UlrichJ is offline
post #8 of 10 (permalink) Old 12-16-2014, 08:45 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
This project may give you some ideas.
Harry
harrysin is offline
post #9 of 10 (permalink) Old 12-22-2014, 12:01 PM
If Larry's bowl/tray is like mine, they have an irregular shape. I have made a bat bowl for Halloween and a Christmas tree bowl.
UlrichJ is offline
post #10 of 10 (permalink) Old 01-07-2015, 05:39 AM
First Name: Yaroslav
Default looking
free patterns anyone ?
slavatarion is offline
Using a portion of a template to make a project kp91 Guide Bushings and Templates 2 06-08-2012 02:45 PM
Template thickness question atmguru222 Guide Bushings and Templates 4 02-27-2011 08:20 PM
How to make a template accurate? Steve Blackdog Guide Bushings and Templates 4 01-02-2011 03:44 PM
Hitachi M12V template guides? vwmowery General Routing 6 08-31-2006 11:51 PM
