template bushings - Router Forums
post #1 of 15 (permalink) Old 11-02-2014, 08:49 PM Thread Starter
Default template bushings
I have a bosh router and have the treaded adapter ra 1100 what bushings will work with this adapter thanks
koolkraft is offline
post #2 of 15 (permalink) Old 11-03-2014, 01:28 AM
N/A; you already have a thread running with this question and replies(?)...
http://www.routerforums.com/introduc...tml#post405050
Are you having trouble with navigating the various forums inside the 'Forum'?
Sometimes there's delays while the moderators check new members' posts for issues.
DaninVan is online now
post #3 of 15 (permalink) Old 11-03-2014, 01:34 AM
porter cable's....
post #4 of 15 (permalink) Old 11-03-2014, 01:35 AM
believe the other thread was for a different style of mounting...
post #5 of 15 (permalink) Old 11-03-2014, 01:44 AM
In any case, Stick, certainly easier to follow if all the comments are in one place, eh?
a) "I have a bosh router and have the treaded adapter ra 1100 what bushings will work with this adapter thanks"
b)"I bought a bosh bushing set but it did not have a 3/8" it has the adapter for other bushings .which other bushings will work with this adapter?Thanks
post #6 of 15 (permalink) Old 11-03-2014, 01:59 AM
True...
so to post more information that hardly ever gets read...
post #7 of 15 (permalink) Old 11-03-2014, 02:07 AM
I read everything you post, Stick! I'm what they call one of your acolytes...
post #8 of 15 (permalink) Old 11-03-2014, 02:15 AM
acolytes... One who assists the celebrant in the performance of liturgical rites???
we going to be in church a lot now???
I use to be an alter boy if that'd help any...
post #9 of 15 (permalink) Old 11-03-2014, 02:17 AM
Rogerdodge's Avatar
First Name: Roger
+1 with DaninVan , Stick. ( and I don't think we are alone ...)
Rog
Been at sea most of my life and still all at sea now.
Sometimes I sits and thinks and sometimes I just sits .
(M Twain)
Rogerdodge is offline
post #10 of 15 (permalink) Old 11-03-2014, 02:26 AM
Default Insert Tab 'A'
Using template bushings Colonel Guide Bushings and Templates 12 12-12-2011 07:57 AM
Template Bushings Guides Setup GaryBirk Table-mounted Routing 11 04-13-2011 02:34 PM
How to make a template accurate? Steve Blackdog Guide Bushings and Templates 4 01-02-2011 03:44 PM
Which template guide bushings do I need for Bosch? sofasurfer General Routing 6 01-31-2010 09:30 PM
