Kempston 99000 Template guide kit - Router Forums
post #1 of 4 (permalink) Old 11-11-2014, 09:36 AM Thread Starter
First Name: Rod
Default Kempston 99000 Template guide kit
Does anyone know if this kit will fit my Makita RP2301? Would I also need the Makita
template guide #321492-3?
Harry? :-)
Thanks for any help!
Rod
Clover4 is offline
post #2 of 4 (permalink) Old 11-11-2014, 10:43 AM
PhilBa's Avatar
First Name: phil
I can't answer your question but the first thing that struck me about that set is the collars have different lengths. Now why would they go do that? I've used different collars on the same template and this would force me to use the thicker template material. Just yesterday I used 2 different collars on the same template. I like my Woodriver (Woodcraft) collar set because it doesn't force me to think about that.
By the way, it's fairly easy to make a base that takes any collar (though PC makes the most sense).
PhilBa is offline
post #3 of 4 (permalink) Old 11-11-2014, 11:24 AM Thread Starter
First Name: Rod
I have the Milescraft set but was looking for a different alternative as I don't always keep the Milescraft base on the router.
I went ahead and ordered the Kempston set. Looking further on the Amazon "questions" page, a user commented the set worked without the Makita adapter... We shall see!
Clover4 is offline
post #4 of 4 (permalink) Old 11-18-2014, 04:23 PM Thread Starter
First Name: Rod
As an update, I received the kit but the adapter will not fit the Makita router. I went ahead and ordered the OEM adapter and it fits like it should. The Kempston must be machined out of spec, as it looks like it should fit but the circumference is a tad too large. I haven't spent much time trying to modify it, but I wanted to warn anyone to be aware of the issue.
Clover4 is offline
Circle cutter guide kit Spuds4you Jigs and Fixtures 4 08-13-2013 05:59 PM
Hitachi Template Guide Installation mtgilbert Guide Bushings and Templates 20 08-02-2009 06:09 AM
Template Guide Kit question rx3584 Guide Bushings and Templates 4 04-01-2009 06:17 PM
The use of template guides (Guide bushes) template tom Portable Routing 28 12-04-2004 08:18 PM
Template Guide depth ttait General Routing 3 10-03-2004 05:16 PM
