Bosch RA1126 template guide holder in router table? - Router Forums
post #1 of 8 (permalink) Old 11-24-2014, 02:48 PM Thread Starter
First Name: Kreg G
Default Bosch RA1126 template guide holder in router table?
Has anybody here used the Bosch quickchange template guide adapter in a router table?
It would appear to be the most convenient way to switch between guide bushings, as long as you use the weak Bosch bushings or have enough Bosch-to-PC adapters not to have to unscrew the PC bushings all the time. Since even Bosch router tables/plates don't appear to include the holes to mount this, it would require fairly precise drilling (using the Bosch subbase) to place this correctly.
I'm thinking of just hanging my MR_23 from its fixed base's subbase in order to try this.
Has anybody tried this?
achoox4 is offline
post #2 of 8 (permalink) Old 11-24-2014, 06:25 PM
First Name: Earl
I use this style insert http://www.amazon.com/Bench-Dog-40-1...nch+dog+insert with a PC style adapter. Don't use guide bushings too much on the table, but DO use a set of Whiteside zero clearance inserts almost all the time.
Does the MR23 sub base have enough lip to be rabbetted into the table top?
earl
greenacres2 is offline
post #3 of 8 (permalink) Old 11-24-2014, 06:39 PM Thread Starter
First Name: Kreg G
Just a few mm. With some support underneath the router body, or perhaps a secondary rabbet to go under part of the base frame, it ought to (just) work.
The plunge base has a larger dia. subbase that would work better. Unfortunately, it has one flat side that would leave an area of exposes base frame on the fixed base, but perhaps that doesn't really matter - it could be positioned toward the fence side of the table, where fewer workpieces reach.
achoox4 is offline
post #4 of 8 (permalink) Old 11-25-2014, 12:20 PM
Earl, what is the purpose of using a zero clearance insert on the router table? I have always wondered, I can see the zero clearance fence purpose.
Herb Stoops is offline
post #5 of 8 (permalink) Old 11-25-2014, 03:02 PM
MT Stringer's Avatar
I am having a hard time grasping the need for guide bushings in a router table. What kind of cuts are you making?
The reason I ask is I use bits with bearings or I position my fence to guide the work piece. I have several insert plates for the Kreg plates that allow for almost zero clearance below the cutter. And I have in the past, attached a temporary fence to close up the gap to either side of the cutter.
More info would be helpful to me.
MT Stringer is offline
post #6 of 8 (permalink) Old 11-25-2014, 05:01 PM Thread Starter
First Name: Kreg G
I intend to rout with a (hole, inside edge) pattern, just as if it was done with the router hand-held, but upside-down, thus without the need to balance the router by hand.
Of course I could use bits with top bearings (or even a bottom bearing for a single dia. hole), but since I'm particularly looking at speaker hole routing where a single template should serve for several different rabbet dia.s and backside chamfers, I'd need several bearing/cutter distances, so that would get expensive (for my standards) quickly.
What does zero clearance mean, esp. under the cutter?
achoox4 is offline
post #7 of 8 (permalink) Old 11-25-2014, 05:05 PM
It's these guys.
http://www.amazon.com/Kreg-PRS3050-T...+router+insert
I pick the one closest to the bit diameter. That way, the workpiece can't accidentally dip as it passes the cutter. Sorry if I confused ya.
One of the blanks I have cut with a hole saw specifically for one particular bit. Now if only I can remember which one, I should be good to go. :-(
post #8 of 8 (permalink) Old 11-25-2014, 06:42 PM
First Name: Earl
I don't know if Whiteside still makes them, but similar to the 12th item or so down this list of products:Woodworking Router Accessories - Peachtree Woodworking Supply
As Mike said, reduces the risk of a dip in the cut, especially at the beginning or end of a cut. Work well handheld or in a table. Bought a router table a few years back, and there were 2 sets unused that were tossed in as part of the deal.
earl
Suggestions for Bosch router for table use Mr.Maim Table-mounted Routing 12 07-31-2013 04:39 PM
Dust Collection on Table Saw Router Table Extension Guitarman1 Table-mounted Routing 0 10-02-2011 02:32 PM
Router template inlay V Garry General Routing 7 12-27-2008 06:49 PM
Bosch Router Table larryc Table-mounted Routing 1 07-06-2008 12:31 PM
