dip bowl... - Router Forums
post #1 of 22 (permalink) Old 12-31-2014, 11:03 PM Thread Starter
Smile dip bowl...
The Strathfield Mens Shed has acquired a small CNC laser cutter and the operator has made a template out of 5mm acrylic that he wants me to trial.
A couple of pictures are attached.
This is very much still R&D at this stage to see what works and what needs to be changed..
The timber is just a round piece of pine from a failed Lazy Susan
Sydney, Australia
jw2170 is offline
post #2 of 22 (permalink) Old 12-31-2014, 11:05 PM Thread Starter
I feel that the template has to be made from 10mm mdf or similar so that the bearing guided dish cutter can be used.
It looks a tad small using a template guide...
Sydney, Australia
jw2170 is offline
post #3 of 22 (permalink) Old 12-31-2014, 11:06 PM
cool...
post #4 of 22 (permalink) Old 01-01-2015, 06:21 AM
neville9999's Avatar
First Name: Neville
Send a message via Yahoo to neville9999
I agree, 6mm is just too thin. N
neville9999 is offline
post #5 of 22 (permalink) Old 01-01-2015, 10:30 AM
James is this to be a bowl/tray? or a cut out part for some other piece of furniture?
OOps, I didn't read the title very well. How does the router slide on the acrylic with the paper still attached?
Herb Stoops is offline
post #6 of 22 (permalink) Old 01-01-2015, 11:02 AM
RainMan 2.0's Avatar
That's a shame James , as my 80watt laser does what I would consider perfect cuts with 6mm plexi , and although it will cut 12mm , it's not great
My tube is giving me issues so maybe I should go to a 120 watt next time , but that involves a new PS and in my case a larger water cooler
Ok ,I never insulate
RainMan 2.0 is offline
post #7 of 22 (permalink) Old 01-01-2015, 11:41 AM
distilling coil in an under counter refrigerator/freezer...
use coolant and not water...
works on our still...
post #8 of 22 (permalink) Old 01-01-2015, 06:03 PM Thread Starter
Hi Herb,
Using the router skis made for me by Harry, the router base does not actually touch the acrylic.
It rides about 3mm above the acrylic and the guide bush rides against the side of the template.
On each side, you lose the amount of the offset and you can see that lip in the pictures.
A round cutout will be made on the top right corner for the dip and the larger bowl is for the crackers...
Sydney, Australia
jw2170 is offline
post #9 of 22 (permalink) Old 01-01-2015, 08:54 PM
First Name: Al
...looks good James.....still looking for oval templates.....anybody got ideas......AL
Al Robins is offline
post #10 of 22 (permalink) Old 01-01-2015, 09:38 PM
draw them up and make your own...
you tube is your friend...
HOW TO DRAW A PERFECT OVAL BY A PAIR OF COMPASS - by Sam Shakouri @ LumberJocks.com ~ woodworking community
Bowl Returning to Lathe BernieW Woodturning and Lathes 1 12-08-2013 03:44 AM
Roughing a Bowl BernieW Woodturning and Lathes 10 12-08-2013 03:26 AM
Elm Bowl BernieW Woodturning and Lathes 2 01-06-2012 09:13 PM
Re-working the Jacaranda bowl harrysin Woodturning and Lathes 8 10-25-2008 01:44 PM
NE Bowl Presentation Mitch12 Woodturning and Lathes 16 06-13-2008 12:27 AM
