Oak Park guide bushs... - Router Forums
post #1 of 6 (permalink) Old 01-23-2015, 10:03 PM Thread Starter
Question Oak Park guide bushs...
I am trying to calculate some offsets for the small dish templates I am making for the current mad rush on making some small coin/key trays.
Also to make the 'plugs' to rout the outside walls..
Does any one know off hand what sizes the OP sets come in.
I also have the Makita 40mm, 30mm, 20mm and 16mm GB's...
I plan to use a 3/4" bowl cutter....
I plan to make some square dishes, also.
Sydney, Australia
jw2170 is offline
post #2 of 6 (permalink) Old 01-24-2015, 11:24 AM
You probaable already have this info? Oak Park Enterprises Ltd.: Catalogue
Sure looks like they are going out of business.
Herb Stoops is offline
post #3 of 6 (permalink) Old 01-24-2015, 06:24 PM Thread Starter
Thanks Herb.
I can probably blame the heat and middle age for the brain fade...
If I use Harry's method, I should be able to work out the requirements for the measurements for the round and the square dishes.
I found a video from The Router Workshop, using the inlay kit which may help for the odd shaped dishes.....
Sydney, Australia
jw2170 is offline
post #4 of 6 (permalink) Old 01-26-2015, 09:34 PM
TWheels's Avatar
I have the official measurements, the OD (outside diameter) and calculated ID. The Oak-Park set was reported as the Outside Diameter but Lee Valley sells a subset and reports both. The Lee Valley dimensions are the basis for my calculated ID of the Oak-Park st.
Oak Park Template Guides312
ID OD
1/8 1/4
0.183 0.308
1/4. 3/8
5/16. 7/16
7/16 9/16
1/2. 5/8
5/8. 3/4
11/16. 13/16
13/16 15/16
7/8. 1
1-1/8 1-1/4
1 1/4 1-3/8
1-3/8 1-1/2
Lee Valley 1 1/2 in inserts, template guides
ID OD
1/4 3/8
5/16. 7/16
1/2. 5/8
5/8 3/4
7/8. 1
1-3/8. 1-1/2
In the reply box I have a nicely column formated table but when posted the spaces largely and erratically disappear.
I Hope to Be the Person My Poodles Believe I Am
The RouterForums member formerly known as mftha or th-alton
"Teach your children what we have taught ours, that the earth is our mother. Whatever befalls the earth befalls the sons of the earth. The earth does not belong to man; man belongs to the earth. Man did not weave the web of life; he is merely a strand in it. We do not inherit the earth from our ancestors; we borrow it from our children."
-attributed to Chief Seattle of the Native American Suquamish Tribe
  • Wood working, especially router work is too much fun to let "disabilities" get in the way.
  • see MEBCWD's signature line; be certain brain is properly powered up and engaged
TWheels is offline
post #5 of 6 (permalink) Old 01-26-2015, 09:42 PM
TWheels's Avatar
Herb, sadly they are going out of the router-related business. I would hope that somewhere on the RouterForums we could at least preserve the information for their jigs, router table and plate dimensions, (including the vacuum attachemens), inlay templates, and all the products unique to them.
TWheels is offline
post #6 of 6 (permalink) Old 01-27-2015, 09:49 PM Thread Starter
"In the reply box I have a nicely column formated table but when posted the spaces largely and erratically disappear."
I had the same trouble when I tried to post a table of Sydney temperatures.
Thanks for answering my post Tom.
I had a brain fade when I made the OP and should have thought it out first....
Sydney, Australia
jw2170 is offline
Oak Park spacer (box) jigs jw2170 Jigs and Fixtures 9 07-29-2013 09:08 PM
Mounting an Oak Park Box Jig on Non Oak Park Table challagan Project Plans and How To 55 06-17-2009 10:18 PM
Oak Park table old folks Table-mounted Routing 4 08-07-2007 11:08 AM
Those of you who have the Oak Park Panel System: Mossy Oak Jigs and Fixtures 1 02-14-2007 08:08 PM
Guide Bushings for Oak Park Base Plate Jim B General Routing 5 12-07-2005 09:39 AM
