Guide Bushings - Page 2 - Router Forums
 3Likes
post #11 of 16 (permalink) Old 08-19-2016, 12:54 AM
TWheels's Avatar
Originally Posted by mbar57 View Post
Being relatively new at this I hope this isn't a completely dumb question (although I read somewhere in here when I registered that the only dumb question is the one not asked). I was looking into buying a set of brass guide bushings and noticed that on some of them the actual guides (the part that sticks out and actually follows the template) were all the same length and on others they some were longer. What is the reason for this? And is there an advantage to one or the other? Thanks in advance for the help.
Originally Posted by Mike View Post
Mike, I just found your question. I prefer the guide bushings that are slightly under 1/4" height for all in the set. They can be used with all templates 1/4" and thicker. Many sets have the longer lengths for larger sizes and this requires thicker templates. I can see no logical reason for this.
PC type guide bushings with a uniform across all sizes of 7/32 height are made by ShopFox and sold by Infinity among other places. For general use I fully agree with Mike there is no logical reason for the variable heights. Some templates, for example letter templates generally use longer lengths.
I have long been a proponent of the Oak-Park larger guide bushings, a subset of which is available from Lee Valley.
These guide bushings have a 1-1/2 incn through bore witha 1-3/4 inch counterbore and a uniform height of 1/4 inch.
I went over to the "Dark Side" (PC guide bushings) when I found my Makita RT0701CX3 trim router could take only the PC style guide bushings. I still wish we had available much larger guide bushings when, for example we go router skiing. I am also looking for the thread in which Bobj3 showed a Oak-Park to PC adapter. The one advtnge of the ShopFox guide bushings over the Oak-Park style is the slightly shorter length.
I Hope to Be the Person My Poodles Believe I Am
The RouterForums member formerly known as mftha or th-alton
"Teach your children what we have taught ours, that the earth is our mother. Whatever befalls the earth befalls the sons of the earth. The earth does not belong to man; man belongs to the earth. Man did not weave the web of life; he is merely a strand in it. We do not inherit the earth from our ancestors; we borrow it from our children."
-attributed to Chief Seattle of the Native American Suquamish Tribe
  • Wood working, especially router work is too much fun to let "disabilities" get in the way.
  • see MEBCWD's signature line; be certain brain is properly powered up and engaged
TWheels is offline
post #12 of 16 (permalink) Old 08-21-2016, 08:09 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
Why Tom would you want large template guides with a trim router? It is of course a different matter with your Makita 3612C.
I'm glad to see you posting.
Harry
harrysin is offline
post #13 of 16 (permalink) Old 08-22-2016, 02:20 AM
TWheels's Avatar
Harry, I am thrilled that you are watching my posts.
Indeed there is no reason to have a larger template guide on a trim router, but then I will try to use it in skiing. Having long been an advocate of the larger template guides, I felt obliged to explain why I knew anything about the PC guides. I do think the Oak-Park/Lee Valley sized guides could be useful for situations in which a template is for some reason such as router bit diameter significantly larger or smaller than the desired product. See for example the contortions I went through in trying to design a way to put a groove around a sign. I designed it using the PC guides because they are the most common, and I wanted to get my head trained to think about using the PC sized guides. It would have been easier and probably more likely to be successful with the larger Oak-Park/Lee Valley guides. What would really have been the easiest would have been to use metric sized guides and router bits.http://www.routerforums.com/general-...ml#post1275105
Last edited by TWheels; 08-22-2016 at 02:24 AM. Reason: make the link work; up my word count.
TWheels is offline
post #14 of 16 (permalink) Old 08-22-2016, 07:37 AM
harrysin's Avatar
First Name: Harry
I'm not sure how you missed out when I was making sets of metric guides for presents to forum members. When I'm well enough to get back into the shed I'll see if I have enough material to make you at least one decent size template guide. All the best my friend.
TWheels likes this.
Harry
harrysin is offline
post #15 of 16 (permalink) Old 08-22-2016, 03:13 PM
TWheels's Avatar
Harry, I was one of the very fortunate recipients of your generosity.
My recent posts in this thread and others were intended for people who might not have Makita routers, not have the bigger template guides and not be necessarily be fluent in metric.
TWheels is offline
post #16 of 16 (permalink) Old 09-11-2016, 01:48 PM
For those unfamiliar with the Makita guide bushings this is what they look like. The bushings shown are: "HarrySin Customs"
Oversized guide bushings and storage Mike Guide Bushings and Templates 7 09-04-2016 11:40 AM
Are all Plunge router guide bushings created equally? RainMan 2.0 Guide Bushings and Templates 20 05-30-2014 11:12 PM
Metric guide bushings for Dewalt 625E & Elu OF97E vjeko Guide Bushings and Templates 13 11-24-2013 01:15 PM
Centering guide bushings...fail Bikeworks Guide Bushings and Templates 9 02-27-2013 07:17 PM
Metric bits and guide bushings Mike The Voting Booth 29 05-09-2012 09:08 AM
