Guide Bushings - Router Forums
 3Likes
post #1 of 16 (permalink) Old 01-27-2015, 06:18 PM Thread Starter
First Name: Mod Team
ModeratorTeam is offline
post #2 of 16 (permalink) Old 01-28-2015, 08:14 PM
chessnut2's Avatar
Moderators......thanks a million for all these. I noticed that the third one down, "Mike - Using Guide bushings" (http://api.viglink.com/api/click?for...t%3E%3C%2Fb%3E doesn't work. And I wasn't able to find it in a search of the forums. Do you know if there is another link for that post? Thanks. Jim
chessnut2 is offline
post #3 of 16 (permalink) Old 01-28-2015, 11:40 PM
Phil P's Avatar
First Name: Phil
Originally Posted by chessnut2 View Post
I noticed that the third one down, "Mike - Using Guide bushings" doesn't work. And I wasn't able to find it in a search of the forums.
Hi Jim the link is slightly wrong - there is a " in there which is in the wrong place
Try this link instead
Mike: Using guide bushings
Mods, could you please correct? Thanks
Regards
Phil
Phil P is offline
post #4 of 16 (permalink) Old 01-29-2015, 12:02 AM
BernieW's Avatar
First Name: Bernie
It should work now. It did when I clicked on it.
Bernie W.
To succeed in life, you need three things: a wishbone, a backbone and a funnybone.
BernieW is offline
post #5 of 16 (permalink) Old 02-03-2015, 08:16 AM
chessnut2's Avatar
Thanks, Phil
post #6 of 16 (permalink) Old 05-02-2015, 07:02 PM
mbar57's Avatar
Being relatively new at this I hope this isn't a completely dumb question (although I read somewhere in here when I registered that the only dumb question is the one not asked). I was looking into buying a set of brass guide bushings and noticed that on some of them the actual guides (the part that sticks out and actually follows the template) were all the same length and on others they some were longer. What is the reason for this? And is there an advantage to one or the other? Thanks in advance for the help.
mbar57 is offline
post #7 of 16 (permalink) Old 06-22-2015, 12:08 AM
Mike, I just found your question. I prefer the guide bushings that are slightly under 1/4" height for all in the set. They can be used with all templates 1/4" and thicker. Many sets have the longer lengths for larger sizes and this requires thicker templates. I can see no logical reason for this.
TWheels and jj777746 like this.
post #8 of 16 (permalink) Old 06-22-2015, 09:07 AM
Honored Member
First Name: pat
More on this, a most important router application.
Quillman is offline
post #9 of 16 (permalink) Old 06-22-2015, 12:19 PM
The original Stanley door butt mortising template required a longer bushing to ride against the pins that guided the cut. And the PC type bushings were commonly used for the routers.
I have had to file off some of mine because of the new plywood thicknesses I use for templates cause them to be too long.
Herb Stoops is offline
post #10 of 16 (permalink) Old 10-19-2015, 03:48 AM
First Name: apple
Many sets have the longer lengths for larger sizes and this requires thicker templates.the PC type bushings were commonly used for the routers
<a href="http://www.howto-trainyourpuppy.com"
title="how to train your puppy">
how to train your puppy</a>
<a href="http://www.vnextsolution.com/" title="Wedding Dress Guide">Wedding Dress Guide</a>
<a href="http://www.vnextsolution.com/" title="Router Settings">Router Settings</a>
<a href="http://en.four-faith.com/"
title="Industrial Router Supplier">
Industrial Router Supplier</a>
fourfaith is offline
Oversized guide bushings and storage Mike Guide Bushings and Templates 7 09-04-2016 11:40 AM
Are all Plunge router guide bushings created equally? RainMan 2.0 Guide Bushings and Templates 20 05-30-2014 11:12 PM
Metric guide bushings for Dewalt 625E & Elu OF97E vjeko Guide Bushings and Templates 13 11-24-2013 01:15 PM
Centering guide bushings...fail Bikeworks Guide Bushings and Templates 9 02-27-2013 07:17 PM
Metric bits and guide bushings Mike The Voting Booth 29 05-09-2012 09:08 AM
