Inlay - using software to create offset templates - Router Forums
 4Likes
  • 4 Post By Gaffboat
post #1 of 5 (permalink) Old 03-29-2015, 05:32 AM Thread Starter
JCJCJC's Avatar
Country: Ireland
Default Inlay - using software to create offset templates
I'm posting this here since it's the sub-forum for guide bushings, and inlay requires guide bushings, hope it's the appropriate place.
I do a bit of inlay work from time to time, using the Milescraft pattern kit and the Bosch system and combinations of both. I want to make my own custom templates, and I want to use graphics software like Adobe or Jasc Paint Shop Pro to do it. I would like to start with an outline drawing, something like a small garden bird in profile view for example, and use the software to offset a line outside the outline drawing line to correspond exactly with the offset required for the router bushing and cutter combination.
Has anybody found a way to achieve this with graphics software?
JC
JCJCJC is offline
post #2 of 5 (permalink) Old 03-29-2015, 03:30 PM
Gaffboat's Avatar
First Name: Oliver
JC
You can do it with Adobe Illustrator. Once you have your original outline in Illustrator, select it and choose Path under the Object Menu. Then choose Offset Path which brings up a dialog box allowing you to set the offset you want. When you click "OK" you're done. Here's what it looks like on a Mac with an older version of Illustrator. Just a note: fine details may be problematical.
Gaffboat is offline
post #3 of 5 (permalink) Old 03-29-2015, 04:15 PM Thread Starter
JCJCJC's Avatar
Country: Ireland
Thank you, both for the content and for taking the trouble to grab all those screens to explain it.
JC
JCJCJC is offline
post #4 of 5 (permalink) Old 05-31-2015, 05:19 AM Thread Starter
JCJCJC's Avatar
Country: Ireland
Default Customising the Milescraft kit
This is where I'm heading with this idea. I've used a top-bearing router bit in my router table to make a plywood copy of the Milescraft template, it's a nice tight fit at the first attempt. Now I can stick down custom artwork generated with Adobe, allowing for the offset, and make my own designs, just using the system to hold the template precisely and/or using the rotation to achieve geometric patterns. I have thinks like oak leaves, swans etc in mind at the moment. I think this has a lot of potential for all Milescraft kit users.
JCJCJC is offline
post #5 of 5 (permalink) Old 06-02-2015, 12:00 PM
LBussy's Avatar
First Name: Lee
This almost makes me believe I could do patterns.
Lee
Kansas City, MO
LBussy is offline
Wood Inlay Templates-More Possibilities w/ More Layers TarterWoodworking Jigs and Fixtures 10 06-08-2015 07:55 AM
For Sale: Misc Router Inlay Templates dovetail_65 Woodworking Classifieds 3 02-21-2011 12:55 PM
Please Help me create a system for templates Doug from Saskatoon Guide Bushings and Templates 6 01-17-2010 03:49 AM
