Template from MDF - Router Forums
 6Likes
post #1 of 11 (permalink) Old 04-03-2015, 10:02 PM Thread Starter
First Name: Deborah
Smile Template from MDF
Evening All
I am in the process of trying to make template form MDF to use for making a bowl with my router. I have cut the template out with the jig saw. My problem is, although I was very careful, the edge is not quite without a few little bumps....I have tried to sand them down, but need to be careful not to make it worse.
Does anyone have a good method to put the finishing touches on a handmade template?
Thanks in advance for your help
Deborah
d2sampson is offline
post #2 of 11 (permalink) Old 04-03-2015, 10:37 PM
RainMan 2.0's Avatar
Is the bowl round ? If so I would have used a circle jig attached to the base of the router for a perfect circle.
I suspect the experts here know how to do an elongated jig if it's not a round bowl
Ok ,I never insulate
RainMan 2.0 is online now
post #3 of 11 (permalink) Old 04-03-2015, 10:42 PM
Hi Deborah, unless you have a circle jig, as suggested by Rick, all I can see is lots of careful sanding.
There are some on the forum that have made many jigs, they may offer an easier solution.
Sydney, Australia
jw2170 is online now
post #4 of 11 (permalink) Old 04-03-2015, 10:48 PM
Deb here's a pic I found when I made an MDF jig with my circle cutter . It was very accurate and I used it for making plexi rings for speakers
post #5 of 11 (permalink) Old 04-03-2015, 10:59 PM
Gaffboat's Avatar
First Name: Oliver
Sanding is probably your best bet. I have also had good success sealing MDF edges with wood glue. Just apply it with your fingers let it dry and sand it. You can build up multiple layers and get a very smooth edge. That won't help major divots but may take care of minor ones.
Gaffboat is offline
post #6 of 11 (permalink) Old 04-03-2015, 11:50 PM
That reminds me of something , I used to repair mistakes with bondo sometimes .
That stuff they use on cars for repairing dents (I think she's a girl?)
Cherryville Chuck likes this.
post #7 of 11 (permalink) Old 04-04-2015, 06:55 AM
First Name: Larry
Deborah make a very thin piece of wood and glue sandpaper to it. It will follow the curve since the wood will bend.
routergieck likes this.
Knot working is offline
post #8 of 11 (permalink) Old 04-04-2015, 07:31 AM
Honored Member
harrysin's Avatar
First Name: Harry
These tutorials of mine may give you some ideas.
File Type: pdf Routing for Beginners - Lesson One(1).pdf (1.50 MB, 121 views)
firstmuller likes this.
Harry
harrysin is online now
post #9 of 11 (permalink) Old 04-04-2015, 08:36 AM
kp91's Avatar
First Name: Doug
I can second bondo as a repair for damaged MDF templates and projects.
RainMan 2.0 likes this.
1 John 1:9
Fredericksburg, VA
kp91 is offline
post #10 of 11 (permalink) Old 04-04-2015, 05:11 PM
JCJCJC's Avatar
Country: Ireland
In general, remember that mdf is formed between rollers, which means that the surfaces are slightly more dense than the middle. If you make templates, they will last longer if you lacquer them heavily, so that the edges soak up the lacquer and are strengthened by it when it dries. As for sanding bumps to perfect your circles, why not make a former with a radius about 2mm bigger than your circle, glue a sanding sheet inside it and sand that way, it is bound to follow the curves and find the high spots only.
JCJCJC is offline
Porter Cable 55160 Omnijig Review Echonav Tool Reviews 19 06-21-2015 03:59 AM
Using a portion of a template to make a project kp91 Guide Bushings and Templates 2 06-08-2012 03:45 PM
Cutting Board, Rounded Corners w/Juice Groove bradleyjere Guide Bushings and Templates 16 09-20-2011 10:48 PM
How to make a template accurate? Steve Blackdog Guide Bushings and Templates 4 01-02-2011 04:44 PM
My first template - a TS throat plate sofasurfer Guide Bushings and Templates 25 03-13-2010 01:25 PM
