Dewalt 625 inner plate - Router Forums
post #1 of 3 (permalink) Old 04-30-2015, 11:36 AM Thread Starter
First Name: jonathan
Default Dewalt 625 inner plate
On the internet, a worktop fitting video shows it being cut with a dewalt 625 by a kitchen fitter called Dave on you tube, video is called tradessupermarket.com on the base of the router there is an infill fitting by trend i think, attached to the infill is a quality 30 mm bush, does anyone know if a trend infill will fit a dewalt 625, thanks all jonathan
Last edited by sweep96; 04-30-2015 at 11:50 AM. Reason: more information will be added
sweep96 is offline
post #2 of 3 (permalink) Old 05-01-2015, 08:03 AM
First Name: Barry
Just fitted one to my DW625 and yes it will fit as the hole centres are the same. BUT, the 'pan head' screws you use to fit it, must have a slim head as the heads will protrude below the base plate. You can't use csk screws. Be careful, Trend make two inner plates and you will need a line up pin assy. The Trend part numbers are listed below.
WP-T10/075 Inner plate T10
WP-T9/090 Line up pin 12mm -1/2 shank T9 and T10
Hope this helps,
bforster is offline
post #3 of 3 (permalink) Old 05-02-2015, 07:23 AM Thread Starter
Thanks for the information Barry.
sweep96 is offline
DW625 type 2 DeWalt Plunge router base plate screws newcal Guide Bushings and Templates 11 07-04-2017 02:53 PM
mounting plate for dewalt 625 jeffl34158 Starting Off 8 07-31-2013 09:50 AM
Fitting Dewalt 625 Router Into Sub Plate Gaia Triton 4 10-11-2010 07:19 AM
Dewalt 625 base plate Giacomo New Member Introductions 4 01-04-2010 02:56 AM
Dewalt 625 issues and questions Greg_R General Routing 9 12-11-2007 04:16 PM
