Helpwith the math - Router Forums
 11Likes
  • 3 Post By Cherryville Chuck
  • 8 Post By Mike
post #1 of 9 (permalink) Old 06-14-2015, 04:01 PM Thread Starter
whimsofchaz's Avatar
First Name: Chuck
Default Helpwith the math
I am making bookcases for my wife and I can't remember the math to determine the offset of a guide bushing to the actual cut going to be made by the bit. I know it's simple and I could struggle and figure it out but I thought one of you could tell me how to figure that out. Also once I have the math will that help me set exact width dado's for the plywood shelves? Thanks
Chuck
whimsofchaz is offline
post #2 of 9 (permalink) Old 06-14-2015, 04:29 PM
The OD of the guide minus D of the bit divided by 2. A 3/4" guide using a 1/2" bit will give a 1/8" offset.
Semipro, Roy Drake and mbar57 like this.
post #3 of 9 (permalink) Old 06-14-2015, 05:42 PM
This may help.
DaninVan, Gaffboat, MYB and 5 others like this.
post #4 of 9 (permalink) Old 06-14-2015, 05:44 PM
Thanks, Mike! I had to keep going back to my router book. Now I can just print it off.
DaninVan is offline
post #5 of 9 (permalink) Old 06-14-2015, 10:35 PM Thread Starter
First Name: Chuck
Thanks Mike I had seen the table before but couldn't remember where it was. Thanks Chuck
post #6 of 9 (permalink) Old 06-14-2015, 11:16 PM
Gaffboat's Avatar
First Name: Oliver
Thanks, Mike. I'm going to print that and stick in my router bit drawer for future reference. It will save doing the math.
Gaffboat is offline
post #7 of 9 (permalink) Old 06-15-2015, 09:58 AM
First Name: Roy
Thanks, Mike. I've saved it.
Roy Drake is offline
post #8 of 9 (permalink) Old 07-17-2015, 05:14 PM
papasombre's Avatar
Country: Venezuela
First Name: Alexis
Me too, Roy.
We, woodworkers are everywhere!!!
papasombre is offline
post #9 of 9 (permalink) Old 07-26-2015, 02:36 PM
Dimitri M's Avatar
Country: Greece
First Name: Dimitri
Lovely! BUT ... if you try to convert inch fractions to decimals for mm measures, prepare yourself for hysteric breakdowns, workpieces to the stove, and finally start knit work rather than woodwork. At least, this is my opinion. I take things the other way: NO bushing, no beating about the bush, and no bu(ll)sh.. I use a straight bit with a proximal bearing of equal width (suitable for template work), and put the straight guide / template where the rim of the dado cut should be. I save myself a lot of trouble, I think. Another thing is, book shelves are constructed for adjustable height. (I don't know why, after they are first used, they are seldom - if ever - changed, mainly because books in a home are deposited like bodies for burial: how many times have you reopened an old book to re-read it?). So, dados are not the way your bookshelf sides should look for adjustable height shelves. Anyway, in my opinion, dados will loosen with the passage of time, either because of shrinking of the shelf (due to moisture loss) or because of movement due to the extra weight of books.
Best wishes
D
Dimitri M
"if you think it is important, you will find a way;
if you think it is not important, you will find an excuse"
Dimitri M is offline
inlay bushing math Mike58 Guide Bushings and Templates 5 11-14-2015 09:31 AM
Math helps for Woodworker's Tagwatts1 General Routing 9 03-28-2015 10:52 PM
Help With Math (no not the new math) lemonyx General Routing 13 02-04-2010 11:38 AM
Miter guage math Enticer Jigs and Fixtures 1 10-21-2006 06:28 PM
