Making clear base for template routing - Router Forums
 37Likes
post #1 of 40 (permalink) Old 07-17-2015, 04:03 PM Thread Starter
First Name: Daryl
Default Making clear base for template routing
I am wanting to make a clear base for my router to do some template routing with. I am thinking about 3/8 thick Lexan but have never worked with any of this material. Wondering about drilling etc. Anyone have any personal experience with this type of project or any ideas would be appreciated.
gelbaugh is offline
post #2 of 40 (permalink) Old 07-17-2015, 04:13 PM
This should help:
http://www.routerforums.com/guide-bu...html#post73038
Nicknurse likes this.
post #3 of 40 (permalink) Old 07-17-2015, 04:26 PM
YUP...
1/4'' is all you need...
read the PDF...
any doubts questions.. ask...
File Type: pdf lexan_polycarbonate_sheet_processing_guide.pdf (2.04 MB, 365 views)
post #4 of 40 (permalink) Old 07-17-2015, 05:18 PM
Honored Member
First Name: pat
"Anyone have any personal experience with this type of project or any ideas would be appreciated." I have & I do.
Unsolicited advice, no priors in Acrylic or Lexan?
Then don't start now. Whilst it is a popular sport, (making plastic base plates), there are too many surprises drilling and routing the stuff for the first time. If you must, do some experimenting first.
For example, acrylic can climb right up a drill bit, weld itself to a saw blade, melt up against a sanding disk, split in 2 when tapped, fill your work space with toxic waste, crack in your face when routed, lacerate you if you try to score & break it x hand, & burn up whilst being flame polished. Moreover, the chip is charged and will spread itself uniformly on all surfaces.
And the adversity is instant and unexpected; a recipe for a bad day, breaking a tool, busting the work and spoiling your set up.
Should be in Mike's safety thread.
These materials are not innocuous, nor are they as easy to work as wood. Wood can absorb mistakes, plastics are unforgiving.
Quillman is offline
post #5 of 40 (permalink) Old 07-17-2015, 05:38 PM
so let's try to help/educate Daryl ....
File Type: pdf Cut, Drill, Finish, and Glue Acrylic.pdf (73.5 KB, 309 views)
Semipro and firstmuller like this.
post #6 of 40 (permalink) Old 07-17-2015, 06:50 PM
Honored Member
First Name: pat
Internet advice is not what he needs. He needs hands on show & tell.
Job and Knock likes this.
Quillman is offline
post #7 of 40 (permalink) Old 07-17-2015, 07:29 PM
RainMan 2.0's Avatar
I know one thing not to do with lexan , cut or engrave it with a laser . The vapours are very unhealthy to humans and also damage the lasers optics . I like plexiglass as its outgasses are mainly co2 .
Most companies that cut plastics with a laser will not touch Lexan . In this case I'm sure it doesn't matter but if I wanted a base I would certainly use my laser to make it
Daryl I've used lexan for car audio applications , and first I cut it as close as possible to the size of the jig , then finish on the router table with a flush bit I think it's called . My scariest episode was when I didn't remove enough material with the jig saw first , then when I put it on the router table the bit caught to much material and jettisoned it across the room bending the router bit.
Never had issues drilling though. I put my drill press on low speed so the lexan doesn't melt and get the drill bit jammed in it
This is the piece that almost took off a finger . But it was 1/2" lexan and I think you'll find I/4" will be easier to work with
Made a ring from mdf to act as a template for guiding the router bit around the plexiglass after it was pre cut
Nicknurse and bryansong like this.
Ok ,I never insulate
RainMan 2.0 is online now
post #8 of 40 (permalink) Old 07-17-2015, 07:55 PM
I say listen to Quillman, he knows what he speaks.
OPG3 and Job and Knock like this.
Herb Stoops is online now
post #9 of 40 (permalink) Old 07-18-2015, 01:23 AM
kauila's Avatar
First Name: Joe
I made a 3/8" thick Lexan base for one of my small routers.
It looks great, but I have recently noticed how the extra thickness makes it more difficult to see the bit doing the routing. The Lexan is clear and it could be that I did not polish the sides of the hole for the bit to go through. It gives a distorted (or maybe a shadowed) view of what I am routing.
The thinner 1/4" thick material recommended by Stick would be how I would go if I did it again.
kauila is offline
post #10 of 40 (permalink) Old 07-18-2015, 03:26 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
This shot shows an Acrylic sub-base that I hurriedly made whilst in the middle of a project when I realized that the router would tilt into the template. I cut a piece of 1/4" Acrylic of unknown type on the band-saw, a jig saw would have been fine, then I placed the plastic base from the router on the centre and marked the mounting holes and which were the drilled and it didn't take much longer than it's taken to compose this post.
CharleyL, TenGees and Nicknurse like this.
Harry
harrysin is offline
Intro and question john spies New Member Introductions 20 12-08-2018 11:08 AM
Router table or Plunge routing template tom Guide Bushings and Templates 15 04-14-2009 02:45 AM
lettering nightmare Birchwood Sign Making 30 01-19-2009 06:22 AM
Sign making, New to routing boom5117 Sign Making 3 07-11-2008 12:58 AM
What tips can you share about making templates for collar guided routing? paulcomi Jigs and Fixtures 6 01-27-2006 02:33 AM
