How Safe are Milescraft - Router Forums
 2Likes
post #1 of 13 (permalink) Old 08-08-2015, 01:44 AM Thread Starter
whimsofchaz's Avatar
First Name: Chuck
Default How Safe are Milescraft
Hi Guys,
I am going to do some routing with a router bushing and have had the Milescraft Turnlock router plate and bushings for years but I have never used them. I have a fitting that will hold the brass bushings I got from Woodcraft. I guess my question is how safe are the Turnlock plastic holders? I remember reading a post years ago about them coming apart as someone was routing. At the time I thought user error but it has always been at the back of my mind. Anybody use them? Mike in "D" I remember you saying something in a post once do you know about them? Thanks for your input
Chuck
whimsofchaz is offline
post #2 of 13 (permalink) Old 08-08-2015, 06:11 AM
paduke's Avatar
I have never had that problem with mine. But my use has been limited, maybe 6 times in four years.
paduke is offline
post #3 of 13 (permalink) Old 08-08-2015, 07:12 AM
I have one on a HF 2hp router, been on there and used nearly every day for 3 years, not a problem out of either one. I can change bushings in it quicker than on my PC's.
dustmagnet is offline
post #4 of 13 (permalink) Old 08-08-2015, 08:46 PM
BrianS's Avatar
First Name: Brian
I've not used them myself, but a member used to swear by them and highly recommend them. Unfortunately he's not with us any longer so can't ask his opinion anymore.
Brian
(Origin uncertain)
BrianS is offline
post #5 of 13 (permalink) Old 08-08-2015, 10:54 PM Thread Starter
First Name: Chuck
The original reason I bought them was their ease of changing bushings and the simple process to use without the bushing. Joe if you have had that kind of use and no problems sounds like I will be okay. Just being cautious it is a router after all.
post #6 of 13 (permalink) Old 08-09-2015, 12:02 AM
Chuck, they work fine. BJ (BobJ3) is the late friend and forum member Brian was talking about. BJ used them all the time and highly recommended them. I got a set just to try them and had no problems with them.
The only difficult to work with plastic guide bushings I know of are the old Craftsman style. They have a very thin neck so you need to be careful to not push them too hard against the template or you end up trimming the plastic.
post #7 of 13 (permalink) Old 08-09-2015, 08:47 PM
N'awlins77's Avatar
First Name: Lee
I've had my set for several years now and have used the heck out of them. Never a problem!!
N'awlins77 is offline
post #8 of 13 (permalink) Old 08-10-2015, 02:48 PM Thread Starter
First Name: Chuck
Thanks Mike, I am going to use the brass bushings I got from Woodcraft with the base plate and insert from Milescraft. I think that should eliminate the thin bushing issue. I am going to use it to cut exact width dadoes in a cabinet for my wife's sewing stuff.
post #9 of 13 (permalink) Old 08-11-2015, 08:08 PM
The only problem I've ever had was with a Milescraft plastic bushing and I really accept part of the blame.
I was using a 3/8" bushing with a 1/4" bit doing a fairly large inlay and there apparently wasn't enough clearance to properly clear the swarf buildup between the bushing and bit. The swarf got hot enough to soften the plastic which deformed at one of the turns and plowed through my template... lesson learned.
John Schaben
jschaben is offline
post #10 of 13 (permalink) Old 08-12-2015, 01:27 AM
Ouch John! Was this with dust collection? Sounds like there wasn't enough room for it to work anyways?
Milescraft sign kit gumball Sign Making 72 03-28-2016 01:30 PM
Basement cabinet for gun safe DelDave61 New Member Introductions 60 11-26-2014 07:41 PM
Bosch MR 23 and Milescraft Turnlock base? achoox4 Guide Bushings and Templates 9 04-10-2013 05:48 AM
Milescraft bushing adapter Clouseau Guide Bushings and Templates 1 02-23-2010 09:16 PM
Jig for the MilesCraft TurnLock bobj3 Jigs and Fixtures 9 11-19-2009 08:31 AM
