Reducing a pattern - Router Forums
 13Likes
post #1 of 37 (permalink) Old 08-22-2015, 08:21 AM Thread Starter
Default Reducing a pattern
I have made a template and have flush trimmed to make copies but need to make another copy 1/4" smaller than the original template. Is there a way to do this? Thanks
Bgjazz is offline
post #2 of 37 (permalink) Old 08-22-2015, 08:32 AM
reduce the size of the bearing by ˝''...
go to a lager dia bit if need be to get the reduction...
ie... 1'' dia bit w/ a ˝'' dia bearing...
or...
step reduce by Ľ'' and making a new pattern that will be 1/8'' smaller...
do this twice...
Wood Chip and ksidwy like this.
post #3 of 37 (permalink) Old 08-22-2015, 09:41 AM
RainMan 2.0's Avatar
Welcome to the forum . Filling out your profile telling a little about yourself and a first name is always nice
Ok ,I never insulate
RainMan 2.0 is online now
post #4 of 37 (permalink) Old 08-22-2015, 09:41 PM
old55's Avatar
First Name: Ross
Welcome to the forum.
Ross,
old55 is online now
post #5 of 37 (permalink) Old 08-22-2015, 10:52 PM
Or use a guide bushing that is 1/4" larger in diameter.
ksidwy likes this.
post #6 of 37 (permalink) Old 08-23-2015, 06:34 AM
plan ''B''......
cut a copy...
leave the template and copy sandwiched together w/ DS tape...
now using a rabbiting bit w/ the bearing adjusted for depth of cut you need to cut the copy to size follow the pattern w/ the bearing and cut the bottom piece down to size...
http://www.infinitytools.com/Rabbet-...ctinfo/00-556/
Herb Stoops likes this.
post #7 of 37 (permalink) Old 08-23-2015, 06:58 AM
Mike..
isn't that going the opposite way????
post #8 of 37 (permalink) Old 08-23-2015, 07:42 AM
Depending on the thickness of the template, wouldn't the quick way to go be to cut a 1/4" wide rabbet (I'm assuming that the pattern is reduced 1/4" all around - otherwise cut an 1/8" wide rabbet) around the pattern to about 1/2 of the thickness, flip it over and use a pattern bit to cut off the lip? this would be done on the copy of course.
Gaffboat likes this.
tomp913 is online now
post #9 of 37 (permalink) Old 08-23-2015, 07:50 AM
wouldn't that ruin the original pattern???...
post #10 of 37 (permalink) Old 08-23-2015, 08:01 AM
TwoSkies57's Avatar
Would just creating a negative template serve your purpose? Bushing to whatever size you want from there as often as you want without all of the hassles??
Skipper the Penguin
TwoSkies57 is offline
Using a pattern bit? tvman44 General Routing 16 03-01-2015 09:25 AM
Trouble Pattern Routing - Help Appreciated marc82much Table-mounted Routing 21 05-05-2014 11:07 PM
wheel pattern gbpack64 General Routing 8 11-05-2012 07:43 PM
Plunge Pattern Bits? Doctor Atomo Router Bits - Types and Usage 4 04-09-2012 04:52 PM
Making Exact Part from Pattern JayMc General Routing 3 02-09-2012 02:57 PM
