Best Template Material - Router Forums
 15Likes
post #1 of 22 (permalink) Old 08-29-2015, 06:23 PM Thread Starter
hammer5573's Avatar
First Name: Hammer
Question Best Template Material
I'm having trouble with my templates developing "soft spots" which cause snipes along the borders of the wood. I've used 1/4" hardboard and various types of plywood, each with the same results. The only thing that seems to work is plexiglass but it's too expensive.
Any suggestions ?
cbwilson likes this.
hammer5573 is offline
post #2 of 22 (permalink) Old 08-29-2015, 06:26 PM
RainMan 2.0's Avatar
I've always used mdf ,usually 3/4" thick. I could see 1/2" working but not big on 1/4" thick templates
cbwilson and Murtu01 like this.
Ok ,I never insulate
RainMan 2.0 is offline
post #3 of 22 (permalink) Old 08-29-2015, 07:19 PM
hawkeye10's Avatar
First Name: Don
Any suggestions ?
What do you mean by "soft spots"? If it's moisture just seal it with a clear coat.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #4 of 22 (permalink) Old 08-29-2015, 07:53 PM
First Name: Lenore
Yep, I was thinking polyurethane, for both moisture and durability. I sealed hardboard glued to 1/2" plywood with a couple coats of oil based poly to make a kitchen work surface for a set of wire shelves (water based probably works as well and dries faster), taking care that the edges were saturated with the first coat. After a few days to let it dry the surface was extremely hard, and 1.5 years of abuse later it has superficial scratches from sharp knives and dragging heavy pots around, but nothing that compromises the coating.
Litterbug is offline
post #5 of 22 (permalink) Old 08-29-2015, 08:35 PM
I use HPDE or chopping board material....
Can be purchased in flat sheets. I use 10mm or 13mm.
Sydney, Australia
jw2170 is offline
post #6 of 22 (permalink) Old 08-29-2015, 08:37 PM
I am also not sure what you mean by "soft spots". Hardboard should be good. I generally use 1/4" MDF but if moisture is the problem MDF would be no better. Sealing may be your best option.
Good Luck
John Schaben
jschaben is offline
post #7 of 22 (permalink) Old 08-29-2015, 10:07 PM
kp91's Avatar
First Name: Doug
3/8" MDF is awesome. Plus it is easily repaired with Bondo if you accidentally damage it.
1/4" works, but some of the template collars are almost that size.
cbwilson and RainMan 2.0 like this.
1 John 1:9
Fredericksburg, VA
kp91 is offline
post #8 of 22 (permalink) Old 08-29-2015, 10:10 PM
BrianS's Avatar
First Name: Brian
I've had good luck using laminate flooring for templates. It can be a bit rough on tools, but once it's sanded to size it's pretty impervious to moisture.
Brian
(Origin uncertain)
BrianS is offline
post #9 of 22 (permalink) Old 08-30-2015, 05:45 AM
CharleyL's Avatar
First Name: Charley
I use tempered MDF, also called Masonite) and 1/4" thick most of the time. For templates that I will want to keep in good condition for a long time I prefer HDPE plastic (cutting board material). I usually buy 1/2 sheet (4 X 4') at a time from a local plastics supplier when they have it in stock, but I have also used about any other plastic sheet that they will sell me if the HDPE isn't available. I don't like to use clear plastic though. I prefer colors, any color over clear, because the clear ones seem to get lost in my shop too easily. Black isn't a very good choice for the same reason.
Charley
Central North Carolina
CharleyL is online now
post #10 of 22 (permalink) Old 08-30-2015, 07:34 AM
HDPE or MDF.
woodman79 is offline
Inlay Material Thickness KomputerMan General Routing 6 10-21-2014 01:39 PM
Best flush trim pattern / template material E. Tinker Jigs and Fixtures 13 03-25-2014 12:35 AM
Template Material CCRT General Routing 10 02-15-2011 10:23 AM
template material mountain monkey Guide Bushings and Templates 37 01-05-2009 08:49 AM
