Milescraft 1204 Spirocrafter pattern question - Router Forums
post #1 of 7 (permalink) Old 09-03-2015, 12:47 PM Thread Starter
First Name: Larry
Default Milescraft 1204 Spirocrafter pattern question
I'm just starting to create cutouts and inlays using the supplied patterns. Just for practice I traced what I thought was a flower petal with 12 petals. Attached picture is from the manual.
What I got was a petal with 12 petals but they cross over one another.
This the picture titled "Traced Flower" attached. I used template 1, pattern window 1. I'm confused about the "Rotation Interval." I started with pattern 1 at the top, slot "A". 2nd, I moved the template counterclockwise 2 positions to the "C" slot, and continued around returning to "A." Why the overlap?
Thanks.
Name:	Traced flower petal.jpg
Name:	Milescraft Manual flower petal.jpg
fishin&routin is offline
post #2 of 7 (permalink) Old 09-03-2015, 07:08 PM
old55's Avatar
First Name: Ross
Can't help you with your query Larry but I'm sure some of our members will be along to help.
Ross,
old55 is offline
post #3 of 7 (permalink) Old 09-03-2015, 08:06 PM
First Name: Earl
I've not used mine nearly enough, but it looks like you perhaps traced the actual opening with a pencil? With a guide bushing, on a router (or rigged to hold a pencil), the tracing will be smaller than the pattern--and reduce or eliminate overlap. No bushing, you get what you drew. Bushing "17" you get their picture. Larger bushing will leave gaps between the petals. I did one a few years ago where i started with the picture in diagram, contrasting inlays (cherry??). Then used a larger bushing, offset--added smaller petals of the boxtop wood (white oak as i recall). Gave it to somebody before i thought to take a picture. It was cool--but i've not done that since.
earl
greenacres2 is offline
post #4 of 7 (permalink) Old 09-04-2015, 03:47 PM
pal
pal's Avatar
First Name: Harold
I would go with earl on this. there is a bushing in the kit that you put a pencil through up one way it is 17 mm the other side is 24 mm if you look at the instructions you attached the 17 mm also applies to that bushing to lay out the pattern as well as the bushing that goes into the router base plate. The spacing that you used A to C is correct It doesn't matter if you go clockwise or anticlockwise.
Harold
Learn from yesterday, live for today, hope for tomorrow. The important thing is not to stop questioning.
Albert Einstein
pal is offline
post #5 of 7 (permalink) Old 09-08-2015, 03:22 PM Thread Starter
First Name: Larry
Default Milescraft Spirocrafter
Thanks, I think you're right, by not using the bushing, this caused the petals to be larger, and thus overlap.
I also have another question. My kit is the 1204, with two templates included. I think the model 1207 has an additional two templates for cutting out patterns with a 1/8" down-cut spiral bit. Just wondering how I could get these two additional templates, and what their numbers are. The templates that came with my set are marked #1 & #2. I'll look for the for sale items here on this forum.
Thanks again.
post #6 of 7 (permalink) Old 09-08-2015, 04:11 PM
pal
pal's Avatar
First Name: Harold
If you go here 1207 - Design/Inlay Kit? - Milescraft you can buy them from milescraft for $7.99 each. They are actually for inlaying the parts numbers you want are 30089 Heart/Star and 30093 Bow tie.
Regards Harold
Albert Einstein
pal is offline
post #7 of 7 (permalink) Old 09-09-2015, 04:32 PM Thread Starter
First Name: Larry
Default Milescraft Inlay Templates
Thanks. I was wondering if I could order them directly from Milescraft.
Introduction & Question re: Milescraft 3-D Pantograph no1texan New Member Introductions 5 07-15-2013 02:30 AM
