Sign making template - Router Forums
post #1 of 2 (permalink) Old 10-07-2015, 02:11 PM Thread Starter
Default Sign making template
Hi, I see people making signs and I was wondering if I could somehow use a router bit with a V-cut or something to follow some 3d printed templates I can make easily.
In the picture you can see a type of sign made that is good quality and then I overlayed a picture of letters that I can print out in template form(vs normal letters as you see in the picture) so that the router bit can guide along it.
I am a novice, and I don't see v cut router bits that have guide bearings so could this work?
lovethepirk is offline
post #2 of 2 (permalink) Old 10-07-2015, 06:51 PM
I'm not sure what you're trying to do, but MLCS sells bearing kits that can be added to a straight shank bit. If you select a bearing that has a larger OD than that of your bit's cutting area, the modified bit could be used to follow a pattern/template - you would just have to calculate the offset between the pattern and bit. MLCS Woodworking Adaptor Bushings and Ball Bearing Guides
tomp913 is offline
Sign Making Question Evil Scotsman Sign Making 15 07-17-2013 02:38 AM
Milescraft sign making kit software? bingocraig Sign Making 2 04-17-2012 07:34 AM
Sign making question and a hello. sliderule2002 New Member Introductions 5 07-29-2010 07:41 PM
Sign template paerley Guide Bushings and Templates 1 04-11-2010 10:52 AM
Making a female template Enticer Guide Bushings and Templates 4 09-05-2009 05:41 PM
