Bosch 1617evs template guides - Router Forums
 3Likes
  • 3 Post By Mike
post #1 of 7 (permalink) Old 11-16-2015, 12:25 PM Thread Starter
nkawtg's Avatar
First Name: Walter
Default Bosch 1617evs template guides
I'm aware I can get them from Bosch, but what is the best template guide design on the market?
nkawtg is offline
post #2 of 7 (permalink) Old 11-16-2015, 03:10 PM
The most common is the Porter Cable design which is 1 3/16" through bore and 1 3/8" counter bore.
post #3 of 7 (permalink) Old 11-16-2015, 04:28 PM
Semipro's Avatar
First Name: John_*
I agree with Chuck.
nice thing about the porter design everybody sell them!
Semipro is offline
post #4 of 7 (permalink) Old 11-16-2015, 04:46 PM Thread Starter
nkawtg's Avatar
First Name: Walter
My bad. I have the 1617EVS not the 1619.
nkawtg is offline
post #5 of 7 (permalink) Old 11-16-2015, 05:15 PM
Semipro's Avatar
First Name: John_*
I corrected IT!
but even so you can make or but a base plate to fit the 1617 that will use the porter cable design
check with Pat Waren (Quillman) http://patwarner.com
Semipro is offline
post #6 of 7 (permalink) Old 11-16-2015, 05:43 PM
Walter, the 1617, MR23 and 1619 all use the same quick change adapter and the same PC style adapter. Bosch's steel bushings are better for rough construction but for home woodworking the PC style in brass is the best option. This is for a couple of reasons: Brass ring nuts will not come loose the way steel ring nuts do which will ruin your cut and possibly your bit. Brass is soft and will not chip the carbide tips should they bump against each other when swapping bits. The Bosch quick release adapter lets you swap or remove/install bushings without changing the bit height. This is a big time saver and no tools required. The sub base plates on current models can be adjusted for perfect center which is critical to getting good results with guide bushings. Bosch offers a centering cone which properly aligns the sub base plate. As long as the sub base plate is not removed this should last indefinitely.
PC style guide bushings come in two types: a set with different collar lengths and a set with all the collar heights the same.(a hair under 1/4") The second option is the one I recommend. This allows you to use 1/4" material for all your templates.(Saves money on template cost, is lighter and easier to store) Woodcraft sells a set like this.
DaninVan, Roy Drake and csscouter like this.
post #7 of 7 (permalink) Old 11-16-2015, 06:02 PM
Honored Member
First Name: pat
In my view, there all compromises.
I think the best ones were the Rosendahl's.
PC/DW are the industry standards.
Notwithstanding, they too, have their compromises.
Quillman is offline
Template Guide for Bosch 1617 hankh Portable Routing 13 11-17-2014 09:59 AM
Producing template when working with template Guides cutter79 Guide Bushings and Templates 9 11-21-2013 01:48 PM
Use of template Guides cutter79 Guide Bushings and Templates 6 08-21-2013 04:18 AM
Template guides question needlerockrick New Member Introductions 4 01-29-2010 10:23 AM
