Bushing insert size for Ryobi - Router Forums
post #1 of 7 (permalink) Old 07-13-2008, 09:02 AM Thread Starter
Default Bushing insert size for Ryobi
Hi, first post here, thought I'd get right to the point.
I just upgraded from a harbor freight trim router to the Ryobi tr45 trim router with the "woodworking base" attachment. I had made a little masonite adapter to make my inlay bushing fit the harbor freight router, but looking at the Ryobi at the store, it looked like it had a pre-made recess for bushings. Well, it doesn't even come close to fitting my inlay bushing, and I was hoping someone here might be able to enlighten me as to what size bushings I should be looking for, where I should look, etc... In a pinch, I could always try to manufacture some kind of adapter myself, but I'd much rather just buy the product that fits to begin with.
Here's pics of the base to give some perspective, hopefully it posts.
Thanks for any info you guys can share!
psychsurf is offline
post #2 of 7 (permalink) Old 07-19-2008, 11:05 PM
Your best bet is to make your own adapter to use PC or Oak Park style bushings.
post #3 of 7 (permalink) Old 03-30-2009, 08:43 PM
superchief's Avatar
First Name: bob
I have just discovered that the Vermont American bushings fit the TR45 base plate perfectly and are tight when the two handle plate is mounted. However VA only has 4 different bushings and may need some modifying for length. I haven't tried using the set up.
Viejo Bob
superchief is offline
post #4 of 7 (permalink) Old 06-01-2009, 09:18 PM
First Name: Chris
Can someone please inform me as to what bushings are used for? Thanks.
redheartwolf is offline
post #5 of 7 (permalink) Old 06-13-2009, 08:33 AM
dutchman 46's Avatar
First Name: Howard
The bushings that they are talking about are, rub collars, i believe. Ryobi uses a special fitting to fill the hole in the base.
John 3:16
dutchman 46 is offline
post #6 of 7 (permalink) Old 06-13-2009, 08:44 AM
Welcome Chris. We use guide bushings of different sizes to follow the edge of a pattern. The size of the bushings determines how much offset there is between the pattern and the wood we are cutting. This is similar to using a bit with a bearing on the end as a guide, but gives many more possibilities. If you want to head down I-75 for about an hour I will set you up to try them out. Nothing teaches as well as doing.
post #7 of 7 (permalink) Old 09-14-2009, 02:17 PM
jonnyspec's Avatar
First Name: Jon
not sure if you found a solution . I did find a universal base plate that fits my ryobi that allows me to use by brass bushing set. I got it from woodcraft.com. works real nice and can now use the finger and dove tail jig .
jonnyspec is offline
guide bushing size chart mharwell01 Guide Bushings and Templates 21 08-18-2017 10:37 AM
Guide bushing identification Mike Guide Bushings and Templates 42 09-22-2013 08:25 PM
Help with bushing & pattern size fdcox Guide Bushings and Templates 4 06-05-2008 02:22 AM
Insert Plate size and 11.5" handle spread; how to prevent problems Ladd Table-mounted Routing 34 12-14-2007 01:08 PM
Inlay Problem boxer Tools and Woodworking 7 04-18-2006 10:10 AM
