Moving the shop from garage to basement - Page 11 - Router Forums
post #101 of 183 (permalink) Old 05-06-2009, 03:51 PM
CanuckGal's Avatar
First Name: Deb
Geez your basement is bigger then my garage! Looks great Jerry! Best wishes for your surgery!
CanuckGal is offline
post #102 of 183 (permalink) Old 05-06-2009, 04:56 PM
TRN_Diesel's Avatar
Looking good Jerry and good luck with your eye surgery. Don't sweat it with time you know it will still be there when you get back so take a break and rest up.
TRN_Diesel is offline
post #103 of 183 (permalink) Old 05-07-2009, 05:40 AM
kz202r's Avatar
Default I moved to the basement too.
I went from a pole barn to the basement a while back, It is nice to have the climate control but the dust and noise can be an issue from time to time
[ATTACH]Moving the shop from garage to basement-100_0892l.jpg[/ATTACH]
kz202r is offline
post #104 of 183 (permalink) Old 05-07-2009, 05:55 PM Thread Starter
xplorx4's Avatar
First Name: Jerry
Tom that desk is awesome!! How long did it take to build? I looked at this post earlier and your attachment and missed the pics!!
I know I will like the basement over the garage at least 2X per year summer and winter!! I like the looks of your shop, maybe you could send a couple more this way. Thanks in advance.
Lamentations 3:22-23
xplorx4 is offline
post #105 of 183 (permalink) Old 05-07-2009, 07:26 PM
kz202r's Avatar
Hi there,The desk was a project that I worked on for a few months in the evening hours. My wife works long hours in the winter months so I can make all the noise I need to during that time. I will load more pics of the shop soon as I can, It seems my computer isnt going to let me do that right now. I'll figure it out and post as soonn as I can.
kz202r is offline
post #106 of 183 (permalink) Old 05-07-2009, 09:33 PM
Dr.Zook's Avatar
First Name: Dave or "Doc"
Jerry, I hope all came out well today.
Your shop is really coming together.
Dave
the "Doctor"
Dr.Zook is offline
post #107 of 183 (permalink) Old 05-07-2009, 11:44 PM
sher622's Avatar
First Name: Jeff
Jerry,
I've got a shop in the basement too. The walls have sheetrock but the ceiling is bare to the joists. I have a feeling that the sound getting into the house is through the ceiling, so I'm curious if you have done anything for sound proofing. The best option I have found, without buying high dollar materials, is to double rock the ceiling after putting up cross member pieces, 1x2, to keep the rock from making full contact with the joists.
sher622 is offline
post #108 of 183 (permalink) Old 05-08-2009, 01:42 AM Thread Starter
xplorx4's Avatar
First Name: Jerry
Hi Jeff
I was fortunate when the house was built; it was built using 18” open web trusses for floor joists. The builder insulated the upstairs from the basement using 8" bats. This gives me a couple advantages, all wire, ducts plumbing is run in the trusses. I will be adding a drop in ceiling and get another measure of sound control plus 8' 10" ceilings. I insulated the exterior walls, (mine is a walk out basement with a garage). I plan on keeping some of the noise producing equipment like air-compressor, dust control etc out there. I have run the saw, Jet 1000B and shop vac and it can be heard up stairs, but it is not loud. Oh yes all the interior walls up and down are insolated to minimize noise and to help with heating and cooling.
xplorx4 is offline
post #109 of 183 (permalink) Old 05-11-2009, 05:38 AM
kz202r's Avatar
Default More shop pics
More shop pics
kz202r is offline
post #110 of 183 (permalink) Old 05-13-2009, 04:27 AM
Country: Thailand
First Name: Jerome
Originally Posted by TRN_Diesel View Post
Looks great Jerry. I cut some more wood today and was amazed how much dust I create. Starting to really consider twhat you have along with a dust control unit.
I have already filled the two shop vac bags with sawdust after I cut all the MDF for the sanding cabinet. The two bags cost me $25.00 so I think it is time I take the plunge but I am still keeping my eyes open for a good used one.
I think you should take a look at either the DD or the Mini CV06 Cyclone Order_Page
I have just completed a month and a half of work and had to empty my paint bucket 3 timesbut all that was in the bag on the CT22 vac was a very small hand full
Here is info on the CV06.
"Great for those who are tired of cleaning the filters on their shop vacuums. If you use your shop vacuum for your small sanders etc., this is a great product for you. Can also be used by contractors to clean up houses ....sheet rock dust etc. It will keep the filter on your shop vacuum from getting clogged. It's sized for a standard 2 1/2" shop vacuum hose for the top and for the inlet. The bottom has a piece of MDF board that can be adapted to a container of your choice.....we figured some would want to put it on a 5 gal pail and others would want to put it on a 55 gal drum. The only requirement is that your container be sealed completely and be strong enough to withstand the vacuum created by the shop vac"
sometimewoodworker is offline
A Little Tour of my Little Shop!.... challagan Tools and Woodworking 31 10-03-2014 11:39 AM
Ed's Shop karateed Workshop Showroom 15 01-06-2012 10:18 PM
Future woodworking shop xplorx4 Lobby 4 12-28-2008 12:45 PM
Setting Up Shop PolarNav New Member Introductions 5 11-26-2008 11:54 PM
heating the shop reikimaster Tools and Woodworking 65 01-05-2008 03:53 PM
