Making Pulley Wheels from Plastic - Router Forums
 4Likes
  • 1 Post By RainMan 2.0
  • 1 Post By Quillman
  • 1 Post By dick in ia
  • 1 Post By Nickp
post #1 of 9 (permalink) Old 08-31-2016, 07:12 PM Thread Starter
Default Making Pulley Wheels from Plastic
I have picked up a router crafter and need to make a replacement plastic 2 1/4" pulley...I saw a link where a guy took a hole saw and cut 3 plastic disks.One was a little smaller than the other 2. He used a drill bit with a 1/4" bit.He sandwiched the small disk between the 2 larger ones and pop riveted the 3 together.I need to know where I can find some 1/8 or so plastic and what is the best kind or right type of plastic?
Flutemaker is offline
post #2 of 9 (permalink) Old 08-31-2016, 07:18 PM
RainMan 2.0's Avatar
Any place that replaces windshields sells plexiglass and lexan . I like lexan as its not so brittle .
It comes in differant thicknesses ( I have 24mm ) so in theory couldn't you just route a groove into the inside of the outside perimeter .
To start , I cut circles out of the lexan using a perfect circle jig and a 1/4" straight bit
Just a heads up , but brace yourself when you see the price for what you would consider a scrap
jj777746 likes this.
Ok ,I never insulate
RainMan 2.0 is online now
post #3 of 9 (permalink) Old 08-31-2016, 07:47 PM
Honored Member
First Name: pat
Would use phenolic laminate (canvass or jeans). AC and PC, and other thermo-plastics, will change shape and melt under load.
Quillman is offline
post #4 of 9 (permalink) Old 09-01-2016, 08:55 AM
First Name: Richard
I would use nylon it's available in a wide variety of thickness and small sheets. You could order the thickness you need and cut a grove in it under $20 for a 10"X 10" sheet. It even comes as a rod 2 1/2" dia, but very expensive ~ $75/ ft.
bluewood is offline
post #5 of 9 (permalink) Old 09-01-2016, 09:05 AM
First Name: Keith
See if you can find a small piece of UHMW plastic. The stuff turns easily on a lathe and is bulletproof.
OK, fess up...which one of you clowns stole my sig? It was right here a second ago.
cocobolo1 is offline
post #6 of 9 (permalink) Old 09-01-2016, 09:18 AM
First Name: Dick
Just a suggestion,
considering the usage involved, I would fire up the old wood lathe and make one out of maple.
RainMan 2.0 likes this.
dick in ia is offline
post #7 of 9 (permalink) Old 09-01-2016, 03:55 PM
Nickp's Avatar
First Name: Nick
Nylon rope pulley might work...like for clotheslines...
Did a google for 2 1/4 plastic pulley and got all sorts of stuff...
The bore might not be right but that might be easier to deal with than making a pulley...
Gaffboat likes this.
Nick
Nickp is online now
post #8 of 9 (permalink) Old 09-01-2016, 05:27 PM
First Name: David
Lightbulb Make your own pulley wheel
Mike,
Take a look at this, it might give you some ideas:-
When my time comes, I want to die like my grandfather did - quietly, and in his sleep - not kicking and screaming like the passengers in his car.
David Dickson is offline
post #9 of 9 (permalink) Old 09-01-2016, 07:44 PM Thread Starter
Some interesting ideas..Thanks everybody!!!!
Dirty Little Secrets with Sign Making... newmexico Sign Making 45 06-18-2016 02:59 PM
Wooden sign making tigger Sign Making 7 09-25-2010 12:03 AM
Making a vase part 1 chippypah Woodturning and Lathes 0 03-04-2008 02:23 AM
X-mas toys for the kiddies? NOT seawolf21 Show N' Tell 29 12-25-2007 09:31 PM
making custom subbase Birchwood General Routing 2 05-15-2005 09:37 PM
