Door Sanding and Finishing Stand - Router Forums
 14Likes
post #1 of 11 (permalink) Old 09-23-2016, 07:14 PM Thread Starter
Dejure's Avatar
First Name: Kelly
Default Door Sanding and Finishing Stand
Had a couple doors to finish and didnít want to fight finishing a side at a time, so I came up with this jig.
Obviously, this has been done countless times before, but I had trouble finding hints at what others used, so I just went for it and thought I'd share it here, in case others had doors to finish and were looking for ideas on handling them.
The same thing could be done using saw horses and a couple screws or nails, but the legs get in the way. I had some 2◊4 scraps I used, with other scraps, to make this.
Initially, I made the supports just tall enough to clear the door when I spun it. It worked beautifully, but bending over to sand and finish proved hard on the back. As such, I added a couple 2x's to raise the doors to a bit above waist and that made working the second door a breeze.
The pipe is just conduit and is secured in the pieces of ply by way of a screw. The pipe slips in a hole I drilled in the door ends. However, the doors are heavy and I didnít want to put all their weight on the (approx. 3/8Ē walls around the holes I drilled, so I drilled holes in plywood scraps and screwed those onto the end of the door to take some of the stress off the areas at the holes.
The door spins nicely for sanding and finishing both sides.
Name:	Door Finishing Jig-1.jpg
fire65, JFPNCM, Gaffboat and 9 others like this.
The reason I have what you want is, I never lent it out before.
Scraps are a myth.
Dejure is offline
post #2 of 11 (permalink) Old 09-23-2016, 07:48 PM
nicely done...
post #3 of 11 (permalink) Old 09-23-2016, 08:26 PM
First Name: Richard
Good plan.
Shop guy is offline
post #4 of 11 (permalink) Old 09-23-2016, 08:50 PM
I LIKE that. Portable, stacks out of the way, usable for some other projects. Last time I did doors, I centered nails in the top and bottom of the doors and flipped them that way, but you have lock nuts on your jig to keep the doors from spinning. I just spun them and put in a third nail to hold them in position. Simpler doors though, no glass.
jj777746 likes this.
post #5 of 11 (permalink) Old 09-23-2016, 10:50 PM
old55's Avatar
First Name: Ross
Good one.
Ross,
ĎMembers are requested to add a first name in their profile as we are a very friendly bunch here'.
old55 is online now
post #6 of 11 (permalink) Old 09-24-2016, 02:07 AM
jj777746's Avatar
Thanks a lot Kelly,I have just recently finished two doors but did them on the floor & had to wait for helpers to turn them for me.Would have been much easier using your "rotisserie".James jj777746
You can't drive a bridge spike with a tack hammer(so I'm told)
jj777746 is online now
post #7 of 11 (permalink) Old 09-24-2016, 08:31 AM
Bushwhacker's Avatar
First Name: David
The mother of invention. I will definitely file this one away for future use, thanks Kelly.
When the enemy is in range, so are you.
Bushwhacker is offline
post #8 of 11 (permalink) Old 09-24-2016, 08:56 AM
First Name: Keith
Smaller version of a car rotisserie. If you're a hot rodder, you've likely seen the bigger version before. Nice job!
Dejure likes this.
OK, fess up...which one of you clowns stole my sig? It was right here a second ago.
cocobolo1 is offline
post #9 of 11 (permalink) Old 09-24-2016, 09:13 AM
RainMan 2.0's Avatar
Wow what a great idea . Awesome solution Kelly
Tell you the truth I had no idea its been done before . I've seen cars on caresals, but never thought of doors . That would sure help an otherwise precarious job
Ok ,I never insulate
RainMan 2.0 is online now
post #10 of 11 (permalink) Old 09-24-2016, 09:25 AM
Contributor of the Month
First Name: thomas
Great idea. I'll keep that for my future use. Thanks.
thomas1389 is offline
Assembly and Finishing table dick in ia Jigs and Fixtures 22 07-19-2016 06:53 AM
Segmented Circle Arrowhead Display Stand routergieck Show N' Tell 16 01-19-2014 07:04 AM
Finishing the way I see it! by Derek Willis. derek willis Woodworking Articles 0 02-28-2011 08:44 AM
Rail Stile / Ply Panel gluing / finishing steps? Nickbee The Finishing Touch 10 12-12-2007 10:22 AM
What about finishing exotic woods? Mike The Finishing Touch 9 03-24-2007 07:11 PM
