Table saw sled with dust collection - Router Forums
 11Likes
post #1 of 12 (permalink) Old 11-30-2016, 02:27 PM Thread Starter
difalkner's Avatar
First Name: David
Default Table saw sled with dust collection
There's really nothing new here but since I just built this I thought I'd post it and it's more about the table saw than the router, but alas, I'm posting it anyway.
I have needed a table saw sled for some time but just kept putting it off, however, I have an ongoing project that is going to require I have one for many repetitive angled and beveled cuts so it was time to build it. One thing I hate about using my table saw is all the dust that flies back at me and covers me in dust but right now I don't really want to build an overhead dust collection system. So since I'll be using this sled often I figured why not build in a little dust control - right!
I already had the piece of Birch plywood from dismantling a shelf unit I build about 30 years ago so with a couple of 2x4's and some Maple for runners I had all the makings. Since I just finished building the CNC router and had some 1/2" MDF on hand so it just made sense to cut the dust collection parts on the CNC. I've only made one cut with the sled but it kept about 95% of the dust off of me so that's a good thing! Some of it still went in the air but I didn't have to wear it! LOL!
There are some other fixtures that will mount to the sled but those aren't ready yet. I'll post photos when I get that completed.
Parts on the CNC -
Sled -
kp91, Ray Newman, billyjim and 2 others like this.
David
Curly Wood Shop on Etsy
Romans 3:23
difalkner is offline
post #2 of 12 (permalink) Old 11-30-2016, 03:55 PM
Nice sled, and I like the idea of incorporating dust collection. I modified the guard for my TS as shown in the attached photo, and it does a nice job of collecting most of the sawdust that would be thrown out into the shop. The only problem is that it's a little nose heavy and I sometimes have to pick it up a little to start the piece through the saw - maybe the hose attachment needs to be further back, or maybe the idea would be to have a support arm coming across the saw with a spring or bungee cord taking up the weight of the hose. I wonder if the same idea would work with the sled - make a three-sided tunnel out of Plexiglas to fit between the ends of the sled and let it float up and down based on the thickness of the material being cut.
difalkner, billyjim and Roy Drake like this.
tomp913 is offline
post #3 of 12 (permalink) Old 11-30-2016, 04:04 PM Thread Starter
difalkner's Avatar
First Name: David
I like your setup but I no longer have the guard so I'd have to make that, as well. And I might do that one day. I have some other ideas on dust collection for the sled but I'll use it a while and see how it performs like it is.
David
Romans 3:23
post #4 of 12 (permalink) Old 11-30-2016, 04:23 PM
kp91's Avatar
First Name: Doug
I'd like to see follow up on how it performs, if it is worth it
1 John 1:9
Fredericksburg, VA
kp91 is offline
post #5 of 12 (permalink) Old 11-30-2016, 06:48 PM
Both are good ideas. Tom you might be able to bolt an arm on the back of the guard that has a counterweight at the end to keep the nose at just above zero weight or enough to prevent bounce.
tomp913 likes this.
post #6 of 12 (permalink) Old 12-01-2016, 08:50 AM
First Name: Dennis
I have been considering this for a while. What did you use to cut the hole? I am concerned about the plastic breaking.
denniswoody is offline
post #7 of 12 (permalink) Old 12-01-2016, 03:31 PM
@Cherryville Chuck
The counterbalance sounds intriguing, might be worth a quick mock-up. The present hose is 2-1/2", I've since acquired a lightweight 1-1/4'(?), bought to use with my sanders and router that may help, and I also have the Rockler hose/cord support that would clamp to the outfeed table - all options. Thanks for the suggestion.
@denniswoody
I just used a new (sharp) hole saw and ran the drill at slow speed/minimal pressure. I did find a wood scrap the width of the inside and sanded a chamfer on the top edge so the it fit tight to the bottom so the plastic was well supported. I had concerns about the plastic splitting or cracking but guess I lucked out.
tomp913 is offline
post #8 of 12 (permalink) Old 12-01-2016, 06:42 PM
First Name: Dennis
Thanks tomp913 I am going to try that tomorrow I think.
post #9 of 12 (permalink) Old 12-01-2016, 07:26 PM
I think about 50% of the dust coming off my saw is above the blade so it's got to make a difference.
post #10 of 12 (permalink) Old 12-01-2016, 09:34 PM
I recall seeing something like this before, but the builder had made a sort of floating bridge that spanned the whole length of the blade's path. So nearly all the dust from above was trapped and removed. It was made of clear plastic and the suction hose was hanging down from above the saw so it didn't get in the way. But this would certainly make a difference on crosscuts to workpieces 6 inches or less width. To trap even more, you could extend the plastic channel out another few inches, just above the maximum height of the blade.
difalkner and tomp913 like this.
Level 1 Novice bdbailey New Member Introductions 13 10-06-2016 08:35 PM
New member from Upper Michigan chiefifd32 New Member Introductions 23 05-24-2016 08:11 AM
Hello bialy100k New Member Introductions 9 05-23-2016 09:31 PM
can you lift the router+plate above the table if you use a dust collection adapter? achoox4 Table-mounted Routing 3 11-27-2014 07:41 PM
Router Table Dust Collection Herb Stoops Table-mounted Routing 8 11-24-2014 01:27 PM
