Work Bench Dog Hole Template - Router Forums
 38Likes
post #1 of 23 (permalink) Old 12-05-2016, 10:48 PM Thread Starter
MT Stringer's Avatar
Default Work Bench Dog Hole Template
Just piddling around on a dreary evening so I thought I would work on a Template/Jig for drilling dog holes in a work bench.
It is designed for a top that is 36 inches wide with 3/4 inch holes every 4 inches. The two holes at the rear are for dogs to position the jig for the next row.
The jig has a 3/4 inch base with another 3/4 inch section glued (or screwed) on top. I will drill the holes for the jig on the drill press so they will be vertical.
In use, I plan to clamp it to the work table top and drill the first row of holes using a Forstner bit. Then move it to the next position and plug the two rear holes to keep it registered properly. I guess we will see how that turns out!
Eventually, I plan to incorporate two of the Kreg Klamp tracks, one along the length of the table and one across the short end also.
I hope to build the jig in the next couple of days.
Note: If you haven't seen my work bench, here are a couple of pics. The top is a solid core door with 7/8 inch dog holes and the Kreg tracks along with a home made aluminum plate so another clamp can be used. This table has worked out really well. It is 30 x 48 inches. My plan for the new one is 36 x 60 inches. I don't have room for anything bigger. I do have an extension that folds down when not needed. That has proven helpful.
Unfortunately, the thickness of the top prevented me from using clamps of any kind. And...I mounted a "box" underneath with a pair of drawers in it so it blocked access from underneath.
That's all about to change this coming year. I have been watching videos of other folks benches and gathering ideas.
Name:	Work Bench Dog Hole Template.jpg
Name:	2013-09-19 12.51.46.jpg
Name:	2014-02-04 11.28.38.jpg
Name:	2014-01-23 14.55.58.jpg
MT Stringer is offline
post #2 of 23 (permalink) Old 12-05-2016, 11:34 PM
RainMan 2.0's Avatar
I'm liking the jig idea with the Forstner bit , as I'm thinking your idea should work well .
Don't know if they make a router bit big enough , but with my Festool track and the adapter connected to my router , I wonder if I could do it that way , as when plunging your likely to have a vertical hole.
I love work benches and always dream about making the ultimate one . The things a guy could implement are endless . Would like to see one that's sturdy , but also has the ability to change height .
Actually I'm getting so excited thinking about it , I may build one before I insulate my garage
Will definitely be looking forward to seeing what you create
Ok ,I never insulate
RainMan 2.0 is offline
post #3 of 23 (permalink) Old 12-06-2016, 03:37 AM
JOAT's Avatar
First Name: Theo
Me, I'd just use an adjustable height chair. Was going to suggest different height platforms, but too easy to walk off and fall. So, I'm thinking the most efficient method would be some type of lift, perhaps one of the smaller car lifts, should be plenty stable enough, I would think anyway.
JOAT is online now
post #4 of 23 (permalink) Old 12-06-2016, 10:09 AM
I have a trough down the center of mine Mike, based on one I saw somewhere and I'm not sure I would ever build one without it. It holds my tape measures, pencils and other marking tools, hex screw driver bits, my bench dogs, a little sandpaper, and utility knives. Those are things you want often and handy so you don't have to go look for them but at the same time they aren't on top of the bench.
post #5 of 23 (permalink) Old 12-06-2016, 10:19 AM
First Name: lee
I think a template is a good idea for drilling bench dogs. You hate to have one hole drilled off.
My workbench has a trough on the back side against the wall. Sure is handy for putting stuff in so it does not get knocked off. I wish my workbench could be out from the wall. I sometimes have to pull it out from the wall so long clamps will fit.
coxhaus is offline
post #6 of 23 (permalink) Old 12-06-2016, 10:53 AM
Everend's Avatar
First Name: Everend
I made a template for cutting mine. It worked pretty well. There was enough play when using previously cut holes as alignment (like you are planning) that over several rows the holes wandered. When I noticed this, i measured and marked the rest, thus helped me adjust.
I used a standard 3/4" router bit in a plunge base (1/4" shank dewalt). There as a little burning but it was the bit I had.
The router had a template bushing on the base so the holds in the template were sized to this, not the 3/4" dog holes. After drilling the holes in the template, I rounded over the top side.
My table top is Baltic birch and I found the amount of chip out on the back side when the bit went through to be too much. So I used a combination of through-the-dog-hole clamps and a bottle jack to hold a backer board under the hole.
MT Stringer likes this.
Everend is offline
post #7 of 23 (permalink) Old 12-06-2016, 10:59 AM
Everend's Avatar
First Name: Everend
Since my template holes are not the same as the dog holes I made stepped dowels where the end was 3/4" and the step was the same as my template hole size.
Some of thelse ideas I got from YouTube. The bench design is Ron Paulk. The bottle jack idea was mine
Everend is offline
post #8 of 23 (permalink) Old 12-06-2016, 11:02 AM
chessnut2's Avatar
Nice, Mike. Are you hyper?
chessnut2 is offline
post #9 of 23 (permalink) Old 12-06-2016, 11:43 AM
I just drew some light pencil lines on my bench top and drilled 3/4" holes with a forstner bit in a hand-held electric drill. I don't see a need for precision greater than +/- 1/8" when positioning dogs or hold downs etc.
My bench has dog holes down one side, in line with the dog on the bench-end vise, and t-track down the other side and across the end opposite the vise. I wish I had put in more track, because I use track-mounted hold-downs far more often than I use dogs.
<Chas>
I'll burn that bridge when I come to it
CharlesWebster is offline
post #10 of 23 (permalink) Old 12-06-2016, 12:45 PM
@Cherryville Chuck
I like the idea of a trough in the center of the bench as I'm always moving things/knocking them on the floor. I was thinking that the depth wouldn't have to be any more than 3/4" to handle pencils, knife, etc. - is that what you have? Also, what is the width of the trough compared to the width of the top? - I've kind of moved away from tops much wider than 30" as "stuff" seems to pile up an arms length away on the back of the bench.
tomp913 is online now
Bench Dog BenchTop vs. The Super Bench, Bench Top Router Table emergencyshutdown Table-mounted Routing 8 11-14-2011 01:58 AM
RouterForums Amateur Night?????? reible General Routing 44 02-10-2009 10:55 PM
Router template inlay V Garry General Routing 7 12-27-2008 06:49 PM
Bench Dog Files Chapter 11 Bankruptcy jennofarc Tools and Woodworking 12 11-18-2007 03:08 PM
building a work bench reikimaster Tools and Woodworking 12 10-13-2006 11:12 AM
