Exact Width Dado & router template jig - Router Forums
 7Likes
post #1 of 17 (permalink) Old 12-11-2016, 09:24 AM Thread Starter
Everend's Avatar
First Name: Everend
Default Exact Width Dado & router template jig
A few months ago I made a template jig, following this design.
One issue I had with this design is that my pocket holes didn't exactly line up with my dado so there was a little lip at the end/joint. After building this one I thought it would be a better design to drop the pocket holes, run everything on 90degree corners and put a tenon on the end of each piece that would ride in the t-slot cut for the set bolt.
This weekend I started another project where I need to cut some dados so I started looking at posts and videos for zero clearance dado jig. I've watched this video several times now
and then Ron Paulk has a couple of videos touching on his version of this one. In Marc's video he challenges his viewers to design a version with the knobs on top. This seemed quite simple, just make the rails or tails a bit larger so the knob and router could fit on top.
While pondering this it it occurred to me that perhaps these two designs could be combined into one. So here's what I came up with. Right now my router table is down because I'm in the middle of building a router lift and don't want to wait until that's done before making these shelves. I have some 1/2" baltic birch left from my truck drawer build, so I've designed this out of two layers of 1/2" ply glued together. The sketchup doesn't have the seam in the middle because it was easier to draw as a single 1" heigh block. But imagine this is two pieces of 1/2" with the dados and rabbits cut before glueing it together.
What do you think, will this work?
Name:	2016-12-11 Router Dado-Template Jig1.jpg
Name:	2016-12-11 Router Dado-Template Jig4.jpg
Name:	2016-12-11 Router Dado-Template Jig3.jpg
Name:	2016-12-11 Router Dado-Template Jig2.jpg
Everend is offline
post #2 of 17 (permalink) Old 12-11-2016, 09:38 AM
Interesting idea. Looks a little frail to me though, and maybe a challenge to store. Proof is in the making though. Let us know how it works.
Ray Newman likes this.
post #3 of 17 (permalink) Old 12-11-2016, 09:42 AM
I have a Dado Wiz for this purpose. Attaches to a track. Really like it, but you have to remember to put a slip of paper in to allow space for glue. I have a little gash in mine from learning the lesson to NOT lift the router up while it is still running.
post #4 of 17 (permalink) Old 12-11-2016, 11:48 AM
Forum Moderator
MT Stringer's Avatar
Here's mine. Works great.
http://www.routerforums.com/jigs-fix...-dado-jig.html
Daikusan and RainMan 2.0 like this.
MT Stringer is offline
post #5 of 17 (permalink) Old 12-11-2016, 11:51 AM Thread Starter
Everend's Avatar
First Name: Everend
I think everyone has to learn that one the hard way. It's funny how often I've forgot that lesson.
Everend is offline
post #6 of 17 (permalink) Old 12-11-2016, 12:00 PM Thread Starter
Everend's Avatar
First Name: Everend
The one question I'm pondering is if this will work well enough as the exact width Dado jig or if I'd be better off building both.
Everend is offline
post #7 of 17 (permalink) Old 12-11-2016, 12:12 PM
Looks good if stiff enough as mentioned Everett but a point to remember is that unless you are using it in some way for lap joints the the amount of adjustment needed will typically only be between 1/4 and 3/4".
post #8 of 17 (permalink) Old 12-11-2016, 12:20 PM
Forum Moderator
Here is some more thinking...and action. I built a simple one time use jig for cutting shelf dadoes for kitchen cabinets. Actually, if I need to use it again, all I have to do is remove the screws, adjust the width for the next work piece, and screw the block back in place.
Lots to read on a cold day! :-)
post #9 of 17 (permalink) Old 12-11-2016, 12:21 PM Thread Starter
Everend's Avatar
First Name: Everend
In the picture all four sides are the same length because I just made one side, made it a component and made three copies. In reality I'll make two sides shorter.
For storage one could separate the joints and set the pieces on a shelf in parallel.
Everend is offline
post #10 of 17 (permalink) Old 12-11-2016, 12:58 PM Thread Starter
Everend's Avatar
First Name: Everend
Here's another pic with sizes.
There is a 1/2"x3" vertical mating surface and 1/2" horizontal mating surface on the tenon in the tslot. With 1/4-20 bolts holding it tight into the t-slot, I expect it will be quite stable.
Off to the shop, I'll post again when I get it built!
Name:	2016-12-11 Router Dado-Template Jig5.jpg
Everend is offline
A Simple Serving Tray oldwoodenshoe Show N' Tell 21 12-17-2014 01:24 PM
Adjustable Dado Jig for Plunge Router diggerop Jigs and Fixtures 3 11-08-2009 02:47 PM
Can i use a makita router with a makita template guide with a porter cable jig? oshinobi Jigs and Fixtures 2 06-17-2009 12:24 AM
New here burlboy New Member Introductions 9 01-15-2009 11:53 AM
