Pocket hole drill bit guide - Router Forums
 32Likes
post #1 of 14 (permalink) Old 12-29-2016, 07:51 PM Thread Starter
RainMan 2.0's Avatar
Default Pocket hole drill bit guide
I seen this and thought what a great addition this would be for my Kreg pocket hole jig .
Looks simple enough to make, even a caveman could do it
BrianS, JFPNCM, MEBCWD and 12 others like this.
Ok ,I never insulate
RainMan 2.0 is offline
post #2 of 14 (permalink) Old 12-29-2016, 08:47 PM
hawkeye10's Avatar
First Name: Don
I am not a cave man. That does look like a nice jig to have. Mine has it built into the pocket hole jig but it isn't as good as yours and I bet yours is easier to use. Thanks for the tip.
RainMan 2.0 likes this.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #3 of 14 (permalink) Old 12-29-2016, 09:05 PM
MT Stringer's Avatar
Thanks Rick. I might have to make one. When I modified my jig, part of the drill bit adjustment guide got covered up.
I might have to double check my PH jigs. IIRC, the 2 holer you clamp to the work piece has different guidelines marked for the bit depth adjustment vs the K4 PH jig.
MT Stringer is online now
post #4 of 14 (permalink) Old 12-29-2016, 09:12 PM
First Name: Ken
I like this. If I ever get heat in my shop I might just have to make myself one.
MT Stringer and RainMan 2.0 like this.
kklowell is offline
post #5 of 14 (permalink) Old 12-30-2016, 08:34 AM
TenGees's Avatar
First Name: Paul
Great idea. I think unfolding and folding my instruction sheet is bound to fail eventually. Tightening the collar can sometimes make it shift, which would be much less trouble with a jig like that.
TenGees is offline
post #6 of 14 (permalink) Old 12-30-2016, 09:56 AM
MEBCWD's Avatar
One more thing to add to my should build list. That list just seems to keep growing.
MEBCWD is offline
post #7 of 14 (permalink) Old 12-30-2016, 11:01 AM Thread Starter
Same here . I haven't built one yet , just seen this pic and thought it was a great idea .
I think I'd just glue the dowel in place at the appropriate location ?
Either that or router each slot the perfect length , but I think that may be hard . Maybe something John or Scott could build with there cnc easy enough .
But ideally I think the KISS rule applies , but I'd drill a little hole and have a storage location for the Allen key though also .
Ok I didn't realize that he embedded a magnet to hold the Allen key . At least I think that's what he did ? If so that's a nice addition
post #8 of 14 (permalink) Old 12-30-2016, 12:47 PM
I like the way it is built,just using a dado,or a router bit, real simple. Thanks for posting ,Rick.
Herb Stoops is online now
post #9 of 14 (permalink) Old 12-30-2016, 01:52 PM
Knothead47's Avatar
Good idea!
OK, let's not talk about my in-laws.
OPG3 and RainMan 2.0 like this.
John T.
Knothead47 is offline
post #10 of 14 (permalink) Old 12-30-2016, 06:32 PM
First Name: frank
Default Pocket Hole Gauge
This is a great Idea, Thank you for posting.
Tagwatts is offline
Newbie installs a mounting plate using one bit... matt1710 Table-mounted Routing 11 01-03-2013 02:34 AM
What Is A Mortiseing Bit? Jerry Bowen Router Bits - Types and Usage 30 12-17-2012 09:04 AM
Tool for drill guide? volunteers Tools and Woodworking 8 03-08-2011 12:32 PM
All thread for router skiis rstermer Jigs and Fixtures 99 08-09-2009 10:54 AM
hole saw vs forstner bit reds_21 Tools and Woodworking 6 03-20-2005 09:48 AM
