Air Cylinder / Clamping Diagram - Router Forums
 8Likes
post #1 of 11 (permalink) Old 01-28-2017, 03:19 PM Thread Starter
UglySign's Avatar
First Name: Ronnie
Default Air Cylinder / Clamping Diagram
Looking to get a few Air Cylinders to do some clamping.
Looking to do a setup to make it Primary / Secondary.
Need a diagram layout on how to route the lines.
Please by all means, correct me with a better layout.
Im stumped.
Thinking of a switch at each clamp too.
Dont want both operating same time when
one is needed or if I need to move one of them etc.
Foot pedal eventually, maybe.
Possible for independence would be novel.
Any takers?
See the attached PDF to get a better idea.
Thanks a batch.
UglySign is offline
post #2 of 11 (permalink) Old 01-28-2017, 05:39 PM
JOAT's Avatar
First Name: Theo
Hmm, seems quite elaborate, just to clamp something. What do you plan on clamping, and how much pressure? I repurposed a caulking gun on a saw sled for a clamp. Worked like a charm, very inexpensive, don't know the pressure but it was capable of quite a more than needed, or desired, and adding another would have no problem. And so very little to go wrong.
TenGees and UglySign like this.
Gather the villagers, pitchforks, torches; we march at dusk!
JOAT is offline
post #3 of 11 (permalink) Old 01-28-2017, 05:59 PM
Cylinders will generally act nearly in unison when operated in that configuration. There is almost always one cylinder favored over others because of small variations in the sysyem. In other words one cylinder may extend before another or others but as soon as pressure starts to build the rest of the system will equalize. The only way to isolate the operationof one from others is to install separate valves at every cylinder that control pressure or release of pressure.
By the way, under those circumstances you show there is no need for double acting cylinders. You might as well use single acting with a spring return since pressure will only be applied in one direction.
UglySign likes this.
post #4 of 11 (permalink) Old 01-28-2017, 07:32 PM Thread Starter
UglySign's Avatar
First Name: Ronnie
@Cherryville Chuck
Thank You .... I've been at this most of the day rackin me brains on it.
But I do see what you mean.
Could I still split the incoming air thru a "Y" to separate each. Wait for pressure of course.
I'll change down to single action like you mention.
@JOAT
Do you know that I have a caulking sitting right in front of me, well hanging on the wall.
Also, I've never given it thought of using one for a clamp. Hmmmf... those lil things that get ya.
I appreciate it tho but I'd like to press a button and wooo at the thump of the air powered pad
crashing down on some timber. Not get hand cranky with it. I will keep that in mind tho when
the times in need. And yes it is less exspensive.
Thanks again fellas
UglySign is offline
post #5 of 11 (permalink) Old 01-28-2017, 07:46 PM
TwoSkies57's Avatar
Make sure the mounting mechanism you use for securing the cylinders are more than able to withstand the pressures generated by the cylinders themselves.
Skipper the Penguin
TwoSkies57 is offline
post #6 of 11 (permalink) Old 01-28-2017, 07:53 PM
boogalee's Avatar
First Name: Al
MT Stringer did something similar for his Kreg pocket jig.
Modifying Kreg pocket hole jig
MT Stringer and UglySign like this.
Al B
boogalee is offline
post #7 of 11 (permalink) Old 01-28-2017, 08:21 PM
Originally Posted by UglySign View Post
@Cherryville Chuck
Whether you need the regulator depends on #1 -compressor operating pressure; #2 -maximum allowable cylinder pressure; and #3 -whether you need to be able to modulate the amount of clamping pressure. If #2 or #3 require you regulate the air pressure then you are better off to regulate the incoming air supply. If you need different clamping pressures at each cylinder then you'll need separate valves at each cylinder. If not, as long as the cylinders share the same air supply all the cylinders should apply roughly similar clamping pressure even if the piston rods aren't extended equal lengths from one cylinder to the next (as in clamping a wedge for example). The amount of pressure applied should equal the psi times the cross sectional area of the piston in the cylinder in square inches.
post #8 of 11 (permalink) Old 01-29-2017, 06:20 AM Thread Starter
UglySign's Avatar
First Name: Ronnie
@TwoSkies57 Bill,
Using 1/8" & 1/4" aluminum tube for my adventures.
They're be secured to whatever surface I place them on.
@boogalee
Yes! I came across that one yesterday and will be trying it.
What do you think, I have the older original metal Kreg Pocket Jig.
I'll give that a shot too.
@Cherryville Chuck - Well we're going to find out. I'll be ordering a
bunch of things and see what works out. Nothing like finding forgotten
paypal $$$. If it doesnt work out then I have the stuff for other things.
If it does work out, then i'll do a detailed drawing and share.
Cherryville Chuck likes this.
UglySign is offline
post #9 of 11 (permalink) Old 01-29-2017, 09:30 AM
OPG3's Avatar
First Name: Otis
Ronnie, While visiting Peachtree Woodworking several months ago, I saw this large tilting-table contraption with multiple air cylinders - the salesman told me it was manufactured by Kreg - it looked really super cool.
OPG3
Tweak everything!
OPG3 is offline
post #10 of 11 (permalink) Old 01-29-2017, 11:27 AM Thread Starter
UglySign's Avatar
First Name: Ronnie
Thumbs up
Well sure why not. I've put off pneumatic stuff too long. Usually intimidated
with all the parts etc. So I figured why not give it a try. From there I will say
the ideas are endless. After seeing many tube vids, theres a few things I'd
like to try and see what does/doesn't work. I'm assuming hydraulics works
the same way in a sense. Thats another intimidating animal in its own.
We shall find out.
UglySign is offline
Clamping Cauls for Box Joints PhilBa Jigs and Fixtures 8 02-22-2016 07:19 PM
Hello and a question about air compressors Joe T CNC CNC Routing 1 11-07-2013 04:48 AM
O-ring Groove on a Cylinder jck General Routing 4 12-14-2011 04:56 PM
Dylos Air Quality Monitor Group Buy BigJimAK The Bargain Bin 0 07-28-2011 12:46 PM
