DIY Box Jig - Router Forums
post #1 of 5 (permalink) Old 02-23-2017, 06:53 PM Thread Starter
First Name: Quenten
Default DIY Box Jig
Hey guy, a few weeks ago somebody posted plans for a box jig. I can't seem to find it now. Anybody remember it & where to find it? I wish I'd saved it then.
Tonto1 is offline
post #2 of 5 (permalink) Old 02-23-2017, 06:56 PM Thread Starter
First Name: Quenten
It was for use on a table saw.
Tonto1 is offline
post #3 of 5 (permalink) Old 02-24-2017, 09:41 AM
Country: Mexico
First Name: Joseph Anthony
Arrow
Maybe this helps you a little:
Making Box Joints | Table Saw | Jig | Woodworking
Cheers.
Joe
RÖENTGEEP is offline
post #4 of 5 (permalink) Old 02-24-2017, 01:12 PM
I found plans just like Joseph's from Fine Woodworking on the net once and built one. It worked reasonably well. However, since then I bought an Ibox jig which is far more versatile. With the jig like I built you must have the same thickness dado stack each time you use it and with the Ibox jig you can put any size stack on and then set the jig to it. Of course if you are using a router instead the bit will stay relatively the same size so that won't be an issue.
By the way, before I took the home made jig apart I used it to make some dentil molding with it. If you look through my uploads you'll find it and the thread that went with the pics.
post #5 of 5 (permalink) Old 02-24-2017, 04:04 PM Thread Starter
First Name: Quenten
Thanks guys!
Tonto1 is offline
Box joint jig revisited Gaffboat Jigs and Fixtures 19 01-11-2015 05:03 AM
Does anyone here OWN a MLCS pins and tails half blind dovetail and box joint jig? The Warthog Jigs and Fixtures 3 08-14-2014 03:18 PM
My version of a router box joint jig Mike Gager Table-mounted Routing 4 03-16-2011 05:00 PM
Box joint jig update horn man Jigs and Fixtures 9 01-07-2010 11:19 PM
Oak Park box jig and stock length horn man Jigs and Fixtures 19 11-17-2009 01:26 AM
