Incra Ls27 inaccurate box joints - Router Forums
 6Likes
  • 2 Post By Cherryville Chuck
  • 1 Post By hawkeye10
  • 1 Post By Shop guy
  • 2 Post By okie GW
post #1 of 7 (permalink) Old 03-02-2017, 07:21 PM Thread Starter
First Name: Harold
Default Incra Ls27 inaccurate box joints
I have an older incra ls First time trying box joints they are to snug. I was using a Irwin carbide 1/2 inch bit. I checked the bit and it varies from .510 near the Shank to .485 at the tip. I am trying to cut 1/2 inch box joints. My setup may be sloppy I will set it back up again tomorrow. Tired of messing with it today. Any ideas greatly appreciated.
okie GW is offline
post #2 of 7 (permalink) Old 03-02-2017, 11:04 PM
The tapered bit will definitely cause you problems. That may not be the only problem but it is one you need to correct.
Roy Drake and Herb Stoops like this.
post #3 of 7 (permalink) Old 03-03-2017, 06:11 AM
hawkeye10's Avatar
First Name: Don
I don't like the quality of Irwin tools. Whiteside bits is what I use now. I have been through the problems of using cheap bits.
https://www.hartvilletool.com/catego...ht-router-bits
furboo likes this.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #4 of 7 (permalink) Old 03-03-2017, 07:09 AM Thread Starter
First Name: Harold
Thanks I think the bit is the problem it is a cheap one that came with a set I bought at Lowes. I just bought a whiteside template set and love the way it cuts. Guess I will have to buy a whiteside for box joints.
okie GW is offline
post #5 of 7 (permalink) Old 03-03-2017, 07:30 AM
First Name: Richard
Buy cheap---get cheap results. Trying to get by with cheap tools is like stopplng your watch to save time. Don't work.
Nickp likes this.
Shop guy is offline
post #6 of 7 (permalink) Old 03-03-2017, 09:24 PM
furboo's Avatar
First Name: Rob
Exactly, it's not just the taper, and you'll have good luck with Whiteside. I have the Incra, and if the bit cuts less than 0.500", you'll have an interference fit. It's the way the Incra works. I had this issue with my Freud bit (with no noticeable taper), but I can't recall exactly how narrow...something like 0.492". With Whiteside bits, I don't have this issue.
Rob
furboo is offline
post #7 of 7 (permalink) Old 03-05-2017, 07:36 PM Thread Starter
First Name: Harold
Default Thanks guys
Thanks for all the good input. The best bit I could buy locally was a Freud 1/2 inch shank 1/2 inch straight cut. It miked out at .502, parallel and straight. Cuts great joints fits like a glove. Just cut some 1/2 inch pine to test the fit good friction fit.
okie GW is offline
Box Joints oldrusty Jigs and Fixtures 11 07-18-2013 02:20 PM
Box joints in cedar? chessnut2 Table-mounted Routing 13 07-10-2013 11:15 PM
Box joints with a groove sead0nkey Table-mounted Routing 2 07-20-2011 08:27 AM
Incra Ultra How-To (Box Joints + Other Stuff) Nickbee Show N' Tell 17 06-22-2009 12:42 PM
Best bit for tight fitting box joints? Nickbee Router Bits - Types and Usage 9 12-31-2007 12:13 AM
