Shop built vs. purchased jigs - Router Forums
 53Likes
post #1 of 27 (permalink) Old 03-08-2017, 08:58 AM Thread Starter
bridger's Avatar
First Name: Bridger
Default Shop built vs. purchased jigs
the factors:
Cost
Shipping time
Specificity
Build quality
Shop time
Engineering
Looks
Etc...
I end up making most of mine.
You?
bridger is offline
post #2 of 27 (permalink) Old 03-08-2017, 09:54 AM
hawkeye10's Avatar
First Name: Don
I enjoy building shop made jigs but in a lot of cases it take me a long time to complete so I buy most of mine. I think build quality in most cases is better. Not near the plastic. I think just about always you can build a better jig at a cheaper than store bought. But I don't build mine out of scrap because i have no scrap. The so called scrap in my shop is just as important as other wood. If it's truly scrap it goes in the trash.
jj777746 likes this.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #3 of 27 (permalink) Old 03-08-2017, 10:17 AM
I think that it would depend on the jig - one time use, multiple uses and, more important, whether it needs to be adjustable. I have both, and the onetime use jigs are made for function and not appearance.
I bought the Kreg jig for drilling cabinets for knobs and pulls, strictly because it could be adjusted for different centers, adjusted for different edge distances, etc. - made sense rather than taking the time to drill holes in pieces of plywood every time you needed to install hardware.
I have an old version of the Rockler Hinge Crafter which I've mainly used for smaller hinges, a Milescraft jig for larger (door-type) hinges but that always struck me as a little hokey in the way they said to line it up for location - I needed to hang some replacement doors, one of them directly on the studs as the original owner had done, and made the jig shown so I could screw it to the studs and rout the recess "in place". I probably overbuilt it, but it will work for me anytime I need to install 3-1/2" hinges.
The jig for routing slots was cobbled together when I was making my adjustable height workbench, but I've used it since then on a couple other projects, the length of slot is "adjustable" by putting a block in the opening to limit router travel. As you can see. it's pretty minimal, I would have made it look prettier if I'd realized now useful is was going to be.
OPG3 and jj777746 like this.
tomp913 is offline
post #4 of 27 (permalink) Old 03-08-2017, 10:49 AM
Gaffboat's Avatar
First Name: Oliver
Both. I do buy some jigs but often cobble something together quickly to to help with a task when I'm in the middle of a project.
chessnut2, MEBCWD, TenGees and 2 others like this.
Gaffboat is offline
post #5 of 27 (permalink) Old 03-08-2017, 12:10 PM
old coasty's Avatar
First Name: Bob
I'm with Don. More fun building my own, and most times a ready built is the inspiration with the needed tweaks to make it better. As Mike said long ago, it doesn't have to look pretty, it just has to work right.
old coasty is online now
post #6 of 27 (permalink) Old 03-08-2017, 01:20 PM
I would rather build my own too. Most are cobbled together with spare pieces of material (I won't use the word scraps) and that way I don't mind taking them apart and burning what is no longer usable and putting the usable pieces back with their friends. Most of the jigs I make are job specific anyway so they would sit around taking up space with the possibility that they would never be used again anyway.
The one exception is that I did buy the Incra Ibox jig last year. I had a home made finger joint jig but it required that I have exactly the same thickness stack on my dado set which was a PITA to set up and the Ibox adjusts to what size you have on so it was worth buying for that reason.
post #7 of 27 (permalink) Old 03-08-2017, 02:22 PM
JOAT's Avatar
First Name: Theo
There is no such thing as scrap wood. Only usable, and non-usable wood.
I'm not sure if I even knew you could buy jigs. Unless maybe what I have always thought of jigs are different from the rest of you - highly possible - after all, what they called a jig saw when I was growing up is now known as a scrollsaw, and a sabresaw is now called a jig saw. But a moot point anyway, because I make my own stuff; that way I get what I want, and not what someone else thinks I want. I'm not building high end furniture anyway, and if I were, I'd still make my own. Do piggy banks count as high end furniture?
Gather the villagers, pitchforks, torches; we march at dusk!
JOAT is offline
post #8 of 27 (permalink) Old 03-08-2017, 03:06 PM
When I was working more, I purchased many items, but with more time, I make many items. And then there's the accuracy question. Some of my home made jigs just would NOT come out exactly right, so I purchased instead.
DesertRatTom is online now
post #9 of 27 (permalink) Old 03-08-2017, 08:53 PM
First Name: Richard
I don't buy anything I can make. Sometimes I have bought because I found I couldn't make something or another and I have bought a few things. I do woodwork for fun and relaxation. Being retired I'm a bit careful ( read frugal or tight ) with my money. I do what I do cause I want to not because some else wants me to except for when Angel says she want me to want to then I say "yes, Honey, I'll get on it tomorrow.
Shop guy is offline
post #10 of 27 (permalink) Old 03-08-2017, 09:04 PM Thread Starter
bridger's Avatar
First Name: Bridger
Making accurate jigs often requires accurate jigs. There is often a bit of a bootstrap thing happening to get the basic stuff up and running. Once you have say an accurate cutting crosscut sled, making accurate parts for other jigs gets a lot easier.
kp91, chessnut2, Dimitri M and 4 others like this.
bridger is offline
Saying goodbye to my shop Duane Bledsoe Lobby 18 04-19-2015 04:59 PM
Finish for shop made jigs dmfotoman The Finishing Touch 5 03-27-2015 08:01 PM
Heavy duty shop built router plate Swallow Table-mounted Routing 7 10-01-2010 06:47 AM
Shop built router lift? TanOak Table-mounted Routing 51 09-13-2010 03:17 AM
Shop Built Table Soapdish Table-mounted Routing 17 02-01-2010 05:38 PM
