Kreg pocket hole screws - Router Forums
 39Likes
post #1 of 26 (permalink) Old 03-11-2017, 10:18 PM Thread Starter
RainMan 2.0's Avatar
Default Kreg pocket hole screws
Guys I fell in love with pocket holes ever since I discovered them here . I'm finding another use for my Kreg pocket hole jig at every turn . I gotta say they seem strong as all heck too.
Question , in the past I have been putting the screws in with my drill or my impact . I couldnt use my impact (which is shorter) very well since the boards are to close, so I started putting the screws in by hand .
I'm finding there not that difficult at all with a screw driver , and find I get a much better feel for them when they bottom out . So I was wondering how others install the screws, with a drill or by hand ?
I suspect I've been doing wrong all this time
Pic below , working on my bathroom. As always , pocket holes to the rescue
BrianS, Wildwood, MEBCWD and 7 others like this.
Ok ,I never insulate
RainMan 2.0 is offline
post #2 of 26 (permalink) Old 03-11-2017, 10:46 PM
kp91's Avatar
First Name: Doug
Impact driver most of the time
A long bit might have worked in your situation above. I have put them in with a ratchet/socket in tight places
OPG3, MEBCWD and Nickp like this.
1 John 1:9
Fredericksburg, VA
kp91 is online now
post #3 of 26 (permalink) Old 03-11-2017, 10:55 PM Thread Starter
I have all lengths of bits , and one was just a tad short and the other just a tad long.
Your right , a ratchet would have worked perfect in this situation.
I was hoping to buy that Twister screwdriver I seen advertised at Home Hardware, but they sold out never to return
kp91 likes this.
post #4 of 26 (permalink) Old 03-12-2017, 12:25 AM
sunnybob's Avatar
Country: Cyprus
First Name: Bob
sunnybob is offline
post #5 of 26 (permalink) Old 03-12-2017, 01:05 AM Thread Starter
Originally Posted by sunnybob View Post
Bob I think I seen one of those when I was a kid? Once only actually
post #6 of 26 (permalink) Old 03-12-2017, 01:25 AM
This is the type I use for really tight spaces: https://www.amazon.ca/Neiko-03044A-M...t+screw+driver except the one I use is sold by LV but I always have a hard time finding it on their site (and it's cheaper from LV too). Another option I use once in a while is a regular 1/4" ratchet with 1/4" hex socket with a 1/4" rare earth magnet inside the socket to hold hex screwdriver bits with. The rare earth magnet will keep the hex bits from falling out of the socket.
OPG3, MEBCWD, TenGees and 3 others like this.
post #7 of 26 (permalink) Old 03-12-2017, 07:12 AM
hawkeye10's Avatar
First Name: Don
I use my drill. I would be afraid my impact would strip a screw out. I could be wrong, I usually am.
Roy Drake likes this.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #8 of 26 (permalink) Old 03-12-2017, 08:15 AM
vchiarelli's Avatar
First Name: Vince
I use my impact driver and haven't had a problem over-driving the screws.
I have a ratchet screwdriver in the shop and a bit brace as well, Rick. Geez, how young are you????
vchiarelli is offline
post #9 of 26 (permalink) Old 03-12-2017, 08:42 AM
First Name: Richard
Sometimes in tight places I use a flexible shaft with a socket and driver bit.
Shop guy is offline
post #10 of 26 (permalink) Old 03-12-2017, 08:43 AM
Everend's Avatar
First Name: Everend
impact driver with 3" or 6" robertson bit. They don't strip the head but it is possible to overdrive it, especially in wet framing lumber. I use pocket hole screws to build fence gate frames, it works great. My pocket hole stepped drill bit has a 1/4" drive shank so I tried it in the impact driver. That didn't work well because the impacting caused the stop to loosen/move. I found after about a dozen holes the drill bit was going all the way through the endgrain because the stop collar had moved so much. Put the drill bit back in the drill and it works great again.
so Impact driver is good for driving, drill is good for drilling.
TwoSkies57, OPG3, TenGees and 1 others like this.
Everend is offline
Pocket hole jigs { KREG } Peter Harrison45 Jigs and Fixtures 20 11-05-2013 09:19 PM
Pocket Hole Jig adot45 Jigs and Fixtures 38 10-20-2013 02:19 PM
Soomerfield Pocket Hole Jig paduke The Bargain Bin 14 02-10-2012 10:47 AM
How to Fill Pocket Hole kawisser Tools and Woodworking 9 10-31-2011 03:01 PM
Pocket hole jig hawker44 Jigs and Fixtures 6 10-23-2005 10:19 AM
