Harbor Freight has a dove tail jig - Router Forums
 9Likes
post #1 of 15 (permalink) Old 05-08-2017, 05:39 PM Thread Starter
First Name: Quenten
Default Harbor Freight has a dove tail jig
I saw this thing last week @ HF. Just glanced at it since I was in a big rush but it looked pretty solid. Anybody ever use it or know if it's any good. $35 seems a bit cheap. I think the price in store was $23 but I can't remember.
https://www.harborfreight.com/catalo...q=DOVETAIL+JIG
Tonto1 is offline
post #2 of 15 (permalink) Old 05-08-2017, 05:45 PM
hawkeye10's Avatar
First Name: Don
I don't know anything about it but there is a saying and I bet you have heard it.
"If it sounds to good to be true it probably is"
Ray Newman likes this.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #3 of 15 (permalink) Old 05-08-2017, 05:49 PM
good luck w/ that...
Stick486 is offline
post #4 of 15 (permalink) Old 05-08-2017, 06:07 PM
Well, at least it doesn't have a motor on it. Now accuracy may be a problem.
HJ
Detroit Burbs
RoutervilleUSA on Etsy
honesttjohn is offline
post #5 of 15 (permalink) Old 05-08-2017, 06:18 PM
Looks like the old basic dovetail jig that Sears and other companies sold before the all the fancy smancy hi priced jigs that are on the market now. I used one many years ago and it did the job, but easy to use, no degree needed like the ones today.
Herb Stoops is offline
post #6 of 15 (permalink) Old 05-08-2017, 06:22 PM
Some HF stuff is OK, but I think the Leigh style jig is taking over the dovetail market.
post #7 of 15 (permalink) Old 05-08-2017, 06:54 PM
vchiarelli's Avatar
First Name: Vince
I have a Craftex (Canadian store) dovetail jig that looks almost identical - bought it used. Took me a bit of time to get it set up but it cuts half-blind dovetails no problem. It does take a bit of fiddling to get it set up, once I did that, I created a couple of samples and labelled them with the settings and the router I used.
I think there are any number of these cheaper jigs available, all made in the Orient, but if you're not after all the bells and whistles they're fine for the money. You can't cut through dovetails with this or make box-joints unless you buy the corresponding templates. BTW, the Craftex is on sale for a mere $109 Canadian.
I wasn't prepared to spend a king's ransom for a dovetail jig and I'm happy with mine.
Buy Dovetail Jig 12in. Craftex With Height Adj at Busy Bee Tools
Danman1957 and Herb Stoops like this.
vchiarelli is offline
post #8 of 15 (permalink) Old 05-08-2017, 07:16 PM
had that jig... ditched it because of of the limitations and capabilities...
was given an omni jig one xmas.. regifited it because it wasn't as advertised and it wanted options and because of of the limitations and capabilities... since then it has been regifited...
now I have the Leigh D pro series... it's sweet.. should have went there to start w/.... sure would have saved a lot of money/time/energy/frustration and would not have put so many limits on myself...
and I've kept my money on this continent.. support your community and your community will support you...
Stick486 is offline
post #9 of 15 (permalink) Old 05-08-2017, 08:05 PM
I have one of those simple ones under the bench somewhere. the one @stick mentioned is one you need a degree in mech. engineering and mathmatics to use, just ask the majority of people who own them. Dove tails are over rated in my opinion anyway, keep it simple, use box joints.
post #10 of 15 (permalink) Old 05-08-2017, 08:05 PM
JOAT's Avatar
First Name: Theo
You can always just make one. That's what I'd do. Plenty of free plans to do it out there.
http://www.routerforums.com/jigs-fix...etail-jig.html
Gather the villagers, pitchforks, torches; we march at dusk!
JOAT is offline
dove tail jig how to carl.p Jigs and Fixtures 5 02-08-2013 06:21 AM
Akeda BC24 Dovetail Jig arrived! Michael H Jigs and Fixtures 13 04-11-2012 10:50 PM
Dove tail jig fstrange Jigs and Fixtures 2 01-22-2006 09:43 PM
router dove tail jig for table Paul Shanks Table-mounted Routing 2 01-14-2006 11:03 AM
rockler dove tail jig reds_21 Jigs and Fixtures 2 03-06-2005 11:04 AM
