Self Centering Mortising baseplate - Router Forums
 15Likes
  • 5 Post By toolmanlh
  • 7 Post By toolmanlh
  • 1 Post By Quillman
  • 2 Post By harrysin
post #1 of 7 (permalink) Old 06-12-2017, 09:03 PM Thread Starter
First Name: Lenny
Default Self Centering Mortising baseplate
I made this baseplate a few years ago based on plans from a book on routers either by Patrick Spellman or Bill Hylton. It consisits of two bronze bushings with an i.d. to match the bolts. The bolts need to be directly in line with the centerl of the bit and an equal distance from the same.
toolmanlh is offline
post #2 of 7 (permalink) Old 06-12-2017, 09:10 PM Thread Starter
First Name: Lenny
I haven't figured out how to post more than one attachment at a time. Here is it in use. Each bushing rides on opposite sides and automatically centers on the workpiece.
post #3 of 7 (permalink) Old 06-12-2017, 09:39 PM
Semipro's Avatar
First Name: John_*
Base plate came out fine looks like it will works well.
As for posting pictures for some reason the software in iPhone or iPad will only post one at time
Semipro is offline
post #4 of 7 (permalink) Old 06-13-2017, 12:44 PM
Honored Member
First Name: pat
There are caveats. One must not relax (for a second) the force on the bushings.
And there is no practical way to stop on the north and south scribes.
Moreover, you can't adjust for an offset-mortise.
It's a good exercise in making a base plate but for this reader it's too risky.
Ray Newman likes this.
Quillman is offline
post #5 of 7 (permalink) Old 06-14-2017, 10:02 AM
Honored Member
harrysin's Avatar
First Name: Harry
Some time ago I posted this link which shows how I made what must be the simplest mortise jig ever.
RainMan 2.0 and toolmanlh like this.
Harry
harrysin is online now
post #6 of 7 (permalink) Old 06-17-2017, 12:32 PM
RainMan 2.0's Avatar
Lenny , that's clever idea . Thanks for posting
Harry , that's also a pretty neat idea using the factory holes
Ok ,I never insulate
RainMan 2.0 is online now
post #7 of 7 (permalink) Old 06-17-2017, 04:57 PM
We had a task one time on a job to mortise out hidden door bottoms into a number of solid core doors. The doors were 3' wide X 1 3/4"thick. the mortise was 2 1/4" deep X 3/4"W X 35" long. At the time we were using PC 695 fixed base routers, plunge router were yet to be developed.
We had a solid carbide 1/2"dia. bit X 3 1/2" long. We set up guide rails clamped to each side of the door,extended out with stops at both ends to stop the cut. We made cuts of 1/8" depth on each pass. it took 2 people to do this as one had to hold onto the router with both hands, while the other switched it on and off and held the vacuum hose , like Pat (Quillman), says it is a very precarious setup, and a little tilt one way or the other means disaster. Especially when the bit is extended over 2" beyond the base plate.
Herb Stoops is offline
Centering your router on a mounting plate Mike Table-mounted Routing 61 01-08-2016 11:28 AM
New DIY Mortising Jig WoodBrewer Jigs and Fixtures 15 10-03-2015 08:28 AM
Do I need to use the plastic baseplate when mounting a router to a router table? bighank Table-mounted Routing 8 02-25-2013 10:56 AM
Centering kit for Hitachi M12VE ClayW Table-mounted Routing 7 11-16-2012 03:12 PM
Centering cone? fooser Table-mounted Routing 7 09-08-2011 03:46 PM
