using old fence turnbuckle for wire clamping tool - Router Forums
 5Likes
  • 2 Post By Cherryville Chuck
  • 2 Post By pinehunter
  • 1 Post By tooler2
post #1 of 10 (permalink) Old 06-19-2017, 09:50 AM Thread Starter
First Name: dave
Send a message via AIM to pinehunter
Default using old fence turnbuckle for wire clamping tool
The images show the old parts, next the adapted parts and finally the assembled tool.
pinehunter is offline
post #2 of 10 (permalink) Old 06-20-2017, 12:43 AM
Interesting Dave. Could you show an example of how it works?
chessnut2 and Herb Stoops like this.
post #3 of 10 (permalink) Old 06-20-2017, 03:30 AM Thread Starter
First Name: dave
Charles the images should explain most things.using old fence turnbuckle for wire clamping tool-dsc00509.jpg
The wire used is plastic coated with a metal core of
0.040" diameter and O.D. of 0.080". Let me know if anything needs additional info.
Regards dave
post #4 of 10 (permalink) Old 06-20-2017, 07:39 AM
First Name: rob
I think a video is in order, I don't know what you are accomplishing or how you are getting there.
Rob
chessnut2 likes this.
tooler2 is offline
post #5 of 10 (permalink) Old 06-20-2017, 10:04 AM
Everend's Avatar
First Name: Everend
Nice, I think I've got it, but a video would be helpful.
I saw Ron Paulk use a store bought tool for wire wrapping a air hose onto a fitting, instead of using a screw hose clamp. He preferred the wire over a clamp because the wire could be easily covered to protect the customer's door jambs and floors from being scratched by a sharp edged screw type hose clamp.
Everend is offline
post #6 of 10 (permalink) Old 06-20-2017, 10:27 AM
vchiarelli's Avatar
First Name: Vince
Like others, I'm not sure what the purpose is or what you're trying to accomplish - a video or a better explanation would be helpful.
vchiarelli is offline
post #7 of 10 (permalink) Old 06-21-2017, 09:47 AM Thread Starter
First Name: dave
The wire binding tool in use.
The tool is used to tension the wire binding and then rotated 180 degrees around the bight to produce 2 clenches secured by the bight. The tails are then trimmed to 1/4" and knocked down. The last image shows a bird feeder hooked on the bracket.
post #8 of 10 (permalink) Old 06-21-2017, 11:09 AM
I'm starting to see it David but the tying off part is still a little fuzzy.
post #9 of 10 (permalink) Old 06-21-2017, 11:17 AM
Everend's Avatar
First Name: Everend
Everend is offline
post #10 of 10 (permalink) Old 06-21-2017, 01:37 PM Thread Starter
First Name: dave
Charles I hope this is a bit clearer.
Regards dave
Split Fence patlaw Table-mounted Routing 15 08-03-2015 11:32 AM
Face Lift for the Router Fence bobj3 Jigs and Fixtures 8 04-07-2013 09:21 AM
Selecting the Correct Router Bit LMT Onsrud (Onsrud) Router Bits - Types and Usage 1 02-07-2012 11:17 PM
Some Thoughts on Fence Control Gilbear Table-mounted Routing 21 04-16-2010 05:38 PM
Pivoting fence arc vs distance? Bogydave Table-mounted Routing 16 01-14-2009 08:49 PM
